Replaced electrical adapter on vehicle, now not all the lights work.
Discussion in 'Wiring' started by insaniak, Mar 12, 2016.
  1. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    I smashed my old electrical adapter on a rock while rock crawling and replaced it with an aftermarket Hopkins one.
    The lights now work a little odd.
    With my vehicle lights off, everything is normal and works fine. Brakes, Hazards, left and right signals.
    With my vehicle lights on, everything EXCEPT the left turn signal (and left signal with hazards) works.
    Now since that light works with my vehicle lights off, it is obviously not the bulb. I'm not sure how this could have happened though.
  2. Novarich
    Novarich Active Member
    354
    29
    Dec 8, 2014
    What kind of plug is it ? 7-flat blade rv, 4-pin flat, 6-pin round?
  3. tombiasi
    5,142
    869
    Since you say you damaged the unit on rocks take a look under there and see if you also damaged any of the wires.
  4. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    The electrical adapter only got smashed on some rocks, it didn't tear out anything. Unplugging and replacing was easy. Nothing else looks damaged.
  5. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    My old one was a standard 7 way and this new one is a 7 way and 4 way combo adapter. My trailer uses the 7 way.
  6. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    These anomalies are usually caused by a bad ground somewhere.
  7. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    Insaniak, did you get it fixed?
  8. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    I did not. I have not done anything else to it since the post.
    I did grab my old one that I still had that I know it worked before and I'm going to put it on to test this weekend and see if it works or not to see if maybe the new one is defective or something else is up.
    Also when the last one broke I just took it off and left it exposed for about 3 months during the winter so there's a good chance water got in there during the winter.
  9. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    Had the same symptoms before, worked fine until I turned the lights on. In that case it was a bad ground. With it exposed all winter, if you have enough slack maybe cut off the corroded ends and try again.
  10. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    Is that what you did? Did you rewire the plug in connections on the harness on the vehicle?
  11. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    Yes, and cleaned and tightened all the clearance and tail light connections too.
  12. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    Where is the ground? is it on the specific light or is it the main one towards the front of the frame?
