Replacement mattresses
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by 2006RAMHEMI1979, Jul 9, 2019.
  1. 2006RAMHEMI1979
    2006RAMHEMI1979 New Member
    Apr 13, 2010
    HI There, been a while since we've owned a trailer since my wife went back to school. We have bought a 1997 Jayco eagle 1006 and it's in need of new mattresses. Anyone in Canada know of any economical choices and what's the thickest mattresses I could have and still close the roof? Thank you in advance
  2. Eric Webber
    Eric Webber Active Member
    269
    167
    Jul 7, 2018
    Montreal, Quebec, Canada
    For my late 90s Coleman Santa Fe, we went to Foam Factory Canada. They offer multiple densities of custom cut foam and even washable custom covers. We tried the firmest a few years back but it was like a rock. Then we went to the medium and it was just right for us. Keep in mind that you are on plywood and not a spring platform or a box spring, so it is less yielding
    This was what I got.
    HD-36 High Quality
    · (1) 82” x 76” x 4” Sheet
    CUT TO: (1) 77” X 70” X 4”
    · (1) 54” X 80” X 4” Sheet
    CUT TO: (1) 77” x 48” x 4”
    Custom Gray & White Covers
    (1) 77” x 70” x 4”
    (1) 77” x 48” x 4”
    · Cutting Charge = $20.00
    · Custom Order Set-Up Charge $12.99
    · Shipping Charges = Included
  3. kitphantom
    12,160
    1,178
    Do the tissue box test to find out the space limitations you have, since those vary a lot depending on camper and even tenting type (some fold smaller than others).
    Place an empty tissue box, or one of similar weight cardboard on the bed platform. Close the pup up as usual. When you open it, the now-squished height of the box is the space you have to work with.
  4. Spridle
    Spridle Well-Known Member
    1,171
    368
    Jun 6, 2011
    We also did foam factory. 5" poly foam. We found the HD36 to be a bit too hard. The 5" foam is great, but it's really a bit too thick and we have trouble getting it all closed. This is a 98 Coleman Mesa. If I had it to do over again, I'd get the 4". We just bought a full sheet and cut it ourselves. Having them cut it is certainly cleaner that what I did on my own. But I'm cheap and I used the excess foam in other things. We are on year 5 of the 5" poly and it still feels brand new.
    For covers we bought king size waterproof covers on Amazon. They are a bit of a sloppy fit, but have held up well and protected the mattress.
  5. jmkay1
    5,482
    2,270
    Definitely do the tissue box test before buying. I used to own a 1990 jayco 1006 and the factory cushions had imprints of the ceiling. So I had no room between cushions and ceiling on mine. I was only able to leave a sheet on my bed anything thicker the roof wouldn't close. My old jayco had the old fashioned canvas that you see on the old army tents so that probably did not help.
