Replacement of Spring in Stabilizer Leg
Discussion in 'Stabilizing Your Camper' started by Reld4, May 19, 2014.
  1. Reld4
    Reld4 New Member
    May 17, 2014
    We recently purchased a used 1995 Coleman Cedar PU and one of the stabilizer legs is missing the spring. Can this spring/part be purchased from a local automotive store (Canadian Tire), or do we need to go to a RV store? Does anyone happen to know the length of the spring? Thanks for your help.
  2. barb_dave
    barb_dave Active Member
    1,731
    Jul 22, 2007
    Wisconsin
    I'd take one off of the other stabilizers and go to the auto parts store and match it with something they may have in stock. If you can get one there I'm sure it would be cheaper than getting it from a camper dealer
  3. dion
    dion Member
    639
    Apr 26, 2012
    We had a problem with the internal spring on one of our jacks, and simply replaced the entire jack. It was this type, and cost us around the price listed, about $17:
    http://www.etrailer.com/Trailer-Jack/Domar/TJ01RT.html
    Yeah, in a way that seems somewhat wasteful for the sake of a spring, but getting a custom spring wouldn't have saved very many dollars, and would have taken quite a search. And now I've got the old jack to use as a source for spare parts in case anything (except that main spring) fails on any of the other jacks.
    Replacement was easy, just unbolt the old jack and bolt on the new one.
  4. 1951 bear
    1951 bear Active Member
    1,063
    Jun 11, 2009
    leitchfield, kentucky
    Had one fail in mine. Hated those Atwood stabs anyhow. Replaced with Ball light trailer Stabs and sand pads. Cost me @$150, but no more wrestling with those lousy Atwoods.
    BEAR
  5. Dubbya
    6,129
    65
    Aug 2, 2011
    Steinbach, MB
    My stabs are welded on, so when the pad fell off, I just bought a new stabilizer at an RV dealer and used the new extension and new spring. Never bothered trying to find one at Canuck Tire, though PartSource might be a better place to look.
    You can always modify another spring as long as it's about the same size/strength.
