Replacement Options for Tail Lights on Coleman Valley Forge Lite
Discussion in 'Miscellaneous Repairs & Maintenance' started by Daniel Schoonover, Jan 5, 2022.
  1. Daniel Schoonover
    Daniel Schoonover New Member
    Dec 11, 2021
    Salem, OR
    Hi! I am new here and I'm making repairs to our "new" trailer a 1981 Coleman Valley Forge Lite.
    I'm working on resolving some issues I've had with my wiring on my new to me Coleman Valley Forge Lite. Unfortunately, as I started working on the taillights the plastic started to break and even though it "works" for now I want to figure out my replacement options.
    So far I have determined that the combination module is by KD-Lamps and they even have a replacement listed in their catalog. I'm not sure if it still available and I'm waiting to hear back. In the meantime, I'm trying to see what my other options are. Considering the current installation I would like to keep my options to surface mount only so I'm considering some of the surface mount options I see at eTrailer. Does anyone have any advice on this?
  2. Arruba
    Arruba Well-Known Member Gold Supporting Member
    707
    371
    Nov 28, 2014
    Central Oregon
    If you’re looking for an OEM like replacement, it can be kinda tough. Tough enough that lots of people just upgrade to the best overall fit they can find. There are LOTS of places that have surface mount tail light assemblies though, both RV centric and otherwise, including EBay. A search across the web and/or a call to your RV local stores may find yours. As for advice, I’ve had good success with Etrailer in general. Unless you’re determined to stay period correct, if finding nothing after looking I’d get the biggest LED light to cover all the holes good that I can find and move on.
    Good luck with it and reply back with what you did in the end.
    NLB and Daniel Schoonover like this.
  3. Raycfe
    17,805
    3,286
    A metal plate could make a new mounting surface for any lights you choose. I had to do that on a Jayco I had.
  4. Daniel Schoonover
    Dec 11, 2021
    Salem, OR
  5. Daniel Schoonover
    Dec 11, 2021
    Salem, OR
    Well shoot as I look more into the LED replacements I would need to figure out a spot to install a resistor. So I think I might end us just going with a replacement incandescent instead.
  6. Arruba
    707
    371
    Nov 28, 2014
    Central Oregon
    If you haven’t already done so, before going away immediately from LED probably want to check that if your car is newer, it isn’t already compatible and/or the light isn’t already resistor equipped. As I understand it, the resistor just strangles down the input voltage to the required LED voltage so it doesn’t either hyper blink and/or burn out.
    Good luck.
  7. Daniel Schoonover
    Dec 11, 2021
    Salem, OR
    I just realized that since I have a 4 pin I don't have backup lights. Strange that the trailer has them but whatever. I guess those holes will just have lights to cover them. Hah!
    Waiting for my new lights...
  8. Everett Bartlett
    Everett Bartlett Active Member
    135
    60
    Aug 2, 2020
    Southern Nevada
    For your stop, Running lights you do not need a resistor. For turn signals it depends on the year of your vehicle, the resistor is to keep the blink rate correct. Example ............ without resistor . . . . . . with resistor.
  9. Daniel Schoonover
    Dec 11, 2021
    Salem, OR
    Yes I know why resistors are potentially needed.
  10. NLB
    NLB Member Silver Supporting Member
    48
    33
    Oct 10, 2021
    West Palm Beach, Florida
    What are the years that should not need a resistor?
  11. Jimbow
    Jimbow Well-Known Member
    1,833
    398
    Nov 30, 2012
    Thank you, I learned something.
  12. Daniel Schoonover
    Dec 11, 2021
    Salem, OR
    So I finished the lights. Since I have a 4 pin I covered the other spot with some reflectors. I'm not 100% happy with the end result as the lights aren't really surface mount IMO when they don't fully mount flush but that is what I end up with when I trust the description.
  13. Arruba
    707
    371
    Nov 28, 2014
    Central Oregon
    While my input and $2.50 will get you a cup of coffee, I think they look good on there. Thanks for sharing the end result.
