replacement tires
Discussion in 'First Time & New Camper Owners' started by cruiser47421, Jun 10, 2009.
  1. cruiser47421
    cruiser47421 New Member
    25
    Sep 10, 2008
    ok I'm having a hard time finding the right kind of replacement tires for the pup and I need some advice. Recently I repacked the wheel bearing and in doing so i noticed the tires were not in good shape,so,I went out and bought a replacement that was the right size (st 175/80 D 13) and when I went to put it on I noticed that the old one was a wieght class D and the new one was a wieght class C. Now I have been calling around and I cant find anyone who has trailer tires in the class D rating(my pup fully loaded is about 3500#) so is there a formula that can tell me if a class C tire(rated at 1360) will be ok with the pup's wieght or am I stuck with trying to track down some class D tires(rated for 1610#).Or should I just check into just regular car tires if the same basic size.
  2. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    You sure you didn't have 185/80/13? Those I have heard of in a D range, however the 175/80s I have not. If I were you, and you have the clearance, go with a set of 185/80/13 D Ranges. I know they exist, as I have a new set of Loadstar 185/80/13 LR-D on my Starcraft. I don't think the C range will be enough, even considering the full 2720 (1360 each tire), that leaves 780lbs on the tongue.. [EEK]
    What make/model camper do you have? 3500lbs on a 13" tire, on a 175/80 to boot doesn't sound right... What is the GVWR on your camper, according to the tag on the pup?
  3. cruiser47421
    25
    Sep 10, 2008
    I have a Viking Legend 2465ST with a gvwr of 3280 and i double checked the tire size and it is the 175/80 D 13. So i guess I'm back on the phone again tomorrow any thoughts as to who I might find to carry them?
  4. my3kids
    my3kids New Member
    48
    Jul 8, 2008
    Randy,
    Look again at the sidewall. You should see something that says "load range C" or "load range D". If all else fails then going ST185/80D13 in a D-range is about .8 inches taller in diameter. Without looking or measuring your wheel wells I would think that would be okay.
    Ray
    07 Fleetwood Saratoga
  5. jim1999
    jim1999 New Member
    1,645
    Jul 8, 2008
    East Central Illinois
    How many tires do you have on your camper. If you have 2 then you need a heavier tire, if you have 4 you are fine.
  6. cruiser47421
    25
    Sep 10, 2008
    if i can find a 185/80 D 13 in a load range C do you think that will be ok? I have about 4 1/2 to 5 inches of clearance between the tires and the bottom of the pup and I do only have 2 tires on the ground its a single axle
  7. 5Star
    5Star New Member
    100
    Jan 17, 2009
    Red Oak, Tx
    Try Discount tire. And try Carlisle trailer tires.
  8. jwolfe01
    jwolfe01 Honeoye, NY
    779
    May 5, 2008
    Honeoye Falls, NY
    Can you go with Radials instead of Bias Plys? Your trailer would most likely handle better and you should be able to find a wider variety out there.
  9. dcj070454
    dcj070454 New Member
    446
    May 14, 2009
    Canton, Ohio
    Tires are like shoes and boots, you need to be comfortable with them. I would lean towards radial but that is my opinion.
