replacing a tire on a 12" rim - Completed
Discussion in 'Tires / Brakes / Bearings / Axles' started by Anthony Hitchings, May 20, 2020.
  1. Anthony Hitchings
    2,468
    1,378
    Mar 2, 2019
    Oakland, California
    I got the old tire off - thanks to the two big "G" clamps, mostly. The tire irons helped a bit, so did one pry bar, not shown. Now I need to clean up the bead seats on the rim.
    And I especially need to let the tire relax back to a useful rim with at the bead seats. It got squeezed on the way over from China. I will allow multiple days for this relaxation.
    Kyle R Thorson and Sjm9911 like this.
  2. Sjm9911
    9,359
    6,760
    I had to do the same to the new tires last time i put them on.
  3. xxxapache
    3,809
    1,958
    I mount the tire and then put a ratchet strap around the tread to push the bead out in order to seat it.
  4. Anthony Hitchings
    2,468
    1,378
    Mar 2, 2019
    Oakland, California
    well, I have a lot of ratchet straps - so if the sun treatment does not work, I know what to do :)
  5. awdblazer
    awdblazer New Member
    18
    Apr 2, 2019
    please tell me you used some sort of lube
  6. Anthony Hitchings
    2,468
    1,378
    Mar 2, 2019
    Oakland, California
    the n
    the new tire has not been mounted yet - it gets the sun-soak-relaxation treatment for a few days
    I will likely use dish detergent for tire lube
  7. kcsa75
    4,856
    2,870
    Sep 9, 2013
    Kansas City
    A tire shop would have done that for you for, probably, $10.
    Tronicus and Sjm9911 like this.
  8. Sjm9911
    9,359
    6,760
    Where's the fun in that?
    generok, kcsa75 and WrkrBee like this.
  9. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    I do a lot of jobs on my own, for "fun". Manually breaking and mounting tires is not one of them.
    Jeep Guy and Tronicus like this.
  10. 1380ken
    1380ken Well-Known Member
    2,663
    1,075
    Nov 7, 2013
    Mass
    All I have is C-clamps
  11. WrkrBee
    5,721
    2,931
    There have been 4 revisions since "C" clamps. I heard that Revision "H" is on the drawing board.
  12. xxxapache
    3,809
    1,958
    I have a Harbor Freight portable tire changer that I bought just for the bead breaker part when changing motorcycle tires. The bead breaker comes in handy. I have used it to swap valve stems in my TT wheels twice.
    I do not use dish soap as a lube because some of it is chlorinated and can corrode metal, particularly aluminum.
    I use Murphys Oil soap as a lube.
  13. Anthony Hitchings
    2,468
    1,378
    Mar 2, 2019
    Oakland, California
    I am retired , I have time to try a few of these things.
  14. 1380ken
    2,663
    1,075
    Nov 7, 2013
    Mass
    I have broken beads by letting the car rotor down on the side of the tire with a 2-4
    Anthony Hitchings likes this.
  15. kcsa75
    4,856
    2,870
    Sep 9, 2013
    Kansas City
    When I was in high school I worked in a full-service gas station and later a truck tire shop. I've had enough "fun" with tires to last a lifetime. You haven't lived till you've fought with a split-rim off of a tractor-trailer rig.
  16. Sjm9911
    9,359
    6,760
    This looks like fun[:D]
  17. generok
    3,176
    1,786
    Feb 7, 2013
    Anchorage, AK
    I broke the bead on mine by using a bottle jack. I put the base of the bottle jack on the bead, then put it under my truck and jacked. I pushed it down off the bead doing that twice. Worked easy. Getting the old tire over the rim was harder since I didn't have a good way to hold the rim down and get on it. I did it once for the experience, then just bought the tires mounted to rims from that point on. I learned a valuable lesson a few years back... never undervalue your own time. Money comes and goes, but time is a one shot deal... spend it on the things you truly value.
  18. Anthony Hitchings
    2,468
    1,378
    Mar 2, 2019
    Oakland, California
    I tried the same bottle jack method (under my receiver) - the bottle jack slid out of position over the surface of the tire and did not work. Also, the POS jack's top retainer came out.
  19. xxxapache
    3,809
    1,958
    You can make a suitable bead breaker out of a few 2 x 4s
  20. bheff
    bheff Well-Known Member
    1,504
    928
    Feb 24, 2011
    NW Arkansas
    I grew up having a dad that owned a trucking company. I've split my fair share of tractor trailer tires. Being 168 pounds in 8th grade wasn't to my advantage lol
    generok and kcsa75 like this.
