Replacing PUP mattresses.
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by Popitlikeitshot, Jun 11, 2020.
  1. Popitlikeitshot
    Popitlikeitshot New Member
    Feb 9, 2020
    Toronto, Ontario, Canada
    We are purchasing new mattresses for our 2000 Palomino Yearling RL. How thick of a mattress do you think we could get away with? We’re looking at foam mattresses.
  2. firepit
    firepit Well-Known Member
    876
    1,059
    Feb 26, 2020
    Nebraska Go Big Red
    I have 3inch memory on top of my factory mattress
  3. Popitlikeitshot
    Feb 9, 2020
    Do you have any issues closing the roof?
  4. fourhallatts
    fourhallatts Well-Known Member
    1,104
    399
    Jul 18, 2015
    North Syracuse, New York
    You can do the tissue box test. Remove your mattress, put a tissue box (a square one, not the rectangular one) on the bunk and lower your roof to close up your pup. When you open it the box will be crushed to the size of the remaining room for your mattress. Check out thepopupprincess.com, her blog explains it and there are pictures (if you are a visual learner like me).
  5. firepit
    876
    1,059
    Feb 26, 2020
    Nebraska Go Big Red
    No...but i have a coachmen clipper 806xls...every model is different my roof is deeper than on my coleman columbia...on it i had to roll them up and tie them with a belt at pack up
  6. Spridle
    Spridle Well-Known Member
    1,180
    377
    Jun 6, 2011
    Tread carefully. We put 5" in our Mesa and it really stressed things badly. I could get it closed. But it ended up damaging things. On the Niagara we have 3" mattresses and 2" to go under it, that we roll up. Makes it easy to get the camper closed without crushing things. It's a bit of a pain, but is so far the best solution we've found.
    NorthernLights likes this.
  7. Sneezer
    2,084
    929
    If your existing mattresses are in good shape, consider a topper. I added a 1.75 or 2.5” one to mine (Can’t remember for sure) and it made a huge difference. My bunks now have interlocking foam mats underneath, original mattress, topper, waterproof mattress cover, then sheets and comforter. I sleep much better in my pup than I do at home. I used a regular foam topper - it was not a memory foam style as I hate those. I don’t get hot like I do with memory foam, and I don’t feel like I am sleeping in a ditch either.
    However, I am at my very max limit for mattress height now. I can’t keep the beds made when I drop the roof, so all the bedding has to be packed up.
  8. HappyTraveler
    HappyTraveler Well-Known Member
    432
    308
    Apr 30, 2019
    New York
    Our original pup mattresses were completely shot; they were hard as a rock and had no give in them at all. So we took them out. Replaced with a coleman air mattress and topped that with a 3" memory foam and then mattress pad and regular bedding.
    We are now able to keep all our bedding, sans pillows, on the bed to close the top by deflating the air mattress first. Much easier to reinflate mattress rather than remaking the bed each time we set up.
    Bonus, best night's sleep ever!
  9. Matthew Rockwell
    Matthew Rockwell New Member
    Jun 11, 2020
    We just bought a Palomino Pony with 48” wide bunks. When we went to clean the mattress covers one of the foams had a lot of mildew on it, so much that we weren’t comfortable sleeping on it. Because of the 48” width it was hard to find a mattress that would fit for a reasonable price. We found a futon mattress from IKEA that was 55” wide for $100! My wife cut it down and we fit it inside the stock cover. It works great!
    towing12345 likes this.
