Replacing the dinette table
Discussion in 'Camper Restoration Projects' started by kskelloggs, Jun 14, 2017.
  1. kskelloggs
    kskelloggs New Member
    29
    Sep 16, 2016
    Wonderful Wyoming
    Was just wondering if anyone has replaced their dinette table with a real wooden table top, using the existing legs and such? I am toying with the idea of building one, and was curious as to comments and ideas and problems, if anyone has tried this. Thanks!
    EmilyW likes this.
  2. Jenkamus
    Jenkamus Active Member
    235
    66
    Oct 17, 2015
    Surprise, AZ
    I plan on building a new on for ours as well, the previous owner trashed it. I don't see a reason it wouldn't work. We will use ours as a back up bed incase we have other guests so I'm just going to make sure its study and reinforced on the bottom to cover any weight.
  3. kitphantom
    12,464
    1,453
    There have been quite a few rebuilds of table over the years, though I'm not sure all the old posts are relocatable.
    Often, the original table is used as a pattern. There were a couple of people who made a lighter version, similar to a hollow core door. Those, IIRC, were not used as beds. Others have made them from plywood or other wood, and either painted or stained them. Some have decoupaged photos or maps to the top. Many of the replacements are lighter than the original wood used.
    Not matter how they've been made, some sort of support framing has been needed to keep them from sagging or breaking, especially when used for a bed.
    EmilyW likes this.
  4. Popiworks
    198
    63
    Jul 22, 2014
    I am going to replace mine with 3/4 in ply. The current flake board is way to heavy. I have some left over white formica and will put white edge banding on it too. My current table has two steel channels support rods that I will carry over together with the folding leg assembly. I'll post a pic when I'm done.
  5. cma7777
    cma7777 Member
    797
    Jan 26, 2011
    North Carolina
    Good luck Popiworks. I need to do the same and hope to learn from your experience.
  6. RollTide30
    RollTide30 Member
    215
    21
    Jan 30, 2017
    West Georgia
    I just broke a corner of my table, so I will be replacing it with some 3/4" plywood. I will most likely use a round over bit to smooth it up and then paint it. I will use the leg from the current table on the new table, but it will have to wait bc we are leaving Saturday morning for our next trip.
  7. Rhconcepts
    Rhconcepts Active Member
    615
    100
    Oct 1, 2015
    Blaine MN
  8. rerspain
    rerspain Active Member
    146
    38
    Jul 26, 2016
    Middlesex, New Jersey
    When I made a new table top. I used the old table as a template. I took the old one and place it over the plywood and drilled through the existing holes into the plywood so I wouldn't have to measure where all the hardware would go.
    EmilyW likes this.
  9. kcsa75
    4,285
    2,273
    Sep 9, 2013
    Kansas City
    Exactly.
    I replaced two table tops and three counters out of a single 4x8 sheet of 3/4 inch plywood plus one 2x3 piece. Then we finished the wood with a stain and urethane. [:)C]
