Replacing the "kitchen" cabinet opposite the door, near the bed
Discussion in 'A-Frame PopUps' started by Anthony Hitchings, Jul 8, 2021.
  1. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    The project crawls along, measure 3x cut once. Home depot 1/2" Birch plywood had some flaws that were revealed when I cut the pieces. I only buy there since I can buy 2 ft x 4 ft pieces . I don't have a wood rack area to store much in the way of wood leftovers.
    I measure the thickness of the full extension drawer slides - just as well - they are thicker than the stated 12.7mm.
    The hardest part is building a "cabinet" but not being able to build the entire box , because the Aliner provides the back and base. It needs to be all-square, but most importantly the two sides need to be parallel. And then the notch for the wheel well adds a complication, because I lose my lower right hand corner as a control point.
    So I am deliberately taking it slow, so I have time to think things over. The cabinets structure will be fully screwed so it can be removed if need be. Drawers will be screwed together, but I may glue the drawer base into its mating slots as all drawer parts are plywood and won't change size.
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,539
    3,448
    No dovetails?
  3. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    I have never done dovetails. I have used a fancy symmetric rabbet - which was great, on our old pantry in San Mateo.
    These drawers get a simple butt joint - its more than adequate for the level of use. I may even include glue.
  4. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    More complications :-(. The Aliner floor has a bow in it, drooping as we go outboard. So the base of both sidewalls has to be shaped to match. For which I am using my corded Ryobi 3x18 thin nosed sander. My 4" Bosch sander is too heavy/clumsy for this fine tuning.
    Hilldweller likes this.
  5. WrkrBee
    6,539
    3,448
    While a Den Leader in Cubs, I picked up some old brass Post Office box combination doors, so we made banks out of them. Scouts had the option of butt, finger, or dovetails joints. Most chose finger or dovetail. I helped them lay it out and they cut them out with a mixture of coping saw, pull saws, dovetail saw, and chisels. The joints were rough, but they learned a little and had a good time. Most of the boys (men now), talk about that one project when they see me, and still have the bank and still remember the combination.
  6. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    OK - I fess up. I did two small projects with dovetails in woodworking shop, in Middle School, back in New Zealand.
    Hilldweller, Sjm9911 and WrkrBee like this.
  7. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    Screws - if anyone cares, I will be using Kreg #8 * 1.5" (SML-C150) flat head coarse threaded pocket screws to fasten my cleats to the pathetic inner plywood on the Aliner walls. I chose them on account of screw geometry and the true self drilling tip (same as the tip on the screws used by Aliner).
  8. tombiasi
    6,639
    2,209
    Did you cut the dovetails by hand?
  9. firepit
    firepit Well-Known Member
    2,545
    4,001
    Feb 26, 2020
    On mine i like that space...i have a narrow bin just tall enough to sit above the wheel well and 3 wider bins stack on top of it and almost reach the wall...They stay put nicely.
    The wheel well is a space killer.
    We put a fan and ceramac heater with the rest of the space...our long cabinet is broken into 3 compartments.
    Wheel well part...furnace register with a cubby hole under it and a small drawer next to bunk...poor design with lots of wasted space. After the wheel well storage imo.
  10. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    Yup!
  11. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    My middle school woodshop had us make a bed tray almost identical to this - but not in bamboo. Its still in existence, back in NZ.
  12. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    Progress:
    Backwards - some of the 1/2" Birch plywood for drawer cases has delaminations (no glue line).
    Forwards: the first (right) side is in place.
    Campeador and Hilldweller like this.
  13. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    Still another problem.
    So I took the right side of the "cabinet" out the the Aliner, and placed it in position (beside the doorway). There is a tapered gap where it abuts the wall.
    Each of the two cabinet sides was made to fit its location - but the Aliner floor apparently has a different bow at each location (even though the locations are only 19 apart C-C). The difference is likely due to the presence of the steel framing for the retractable steel step. ( or I am just not competent enough to get it right in the first place)
    My current thought is to remove the right side wall, place the left side wall, and use my big 4x24 Bosch belt sander to adjust the base of the right wall to suit. The notion here is that the floor closer to the steel step is more likely correct (less slope). So this is wha'ts happening, now the left side is in place and the right side's base is being fitted-to-suit with the big belt sander.
  14. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    Well - cabinet is now in place, minus the top (so that its easier for me to screw in two drawer slides not yet in my possession, though I did pre-dreil anb pre-screw the fastening locations). Now I move on to fabricating the drawer boxes.
    Econ and Sjm9911 like this.
  15. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    Done !!
    It ain't fancy, and I don't care. Main thing is - the drawers slide and are full extension.
    So now we have a custom lower cabinet and we also use the portable metal storage unit on top. And DW has two drawers in the custom-built portable galley on the opposite side of the Aliner.
    Campeador, Econ, Hilldweller and 2 others like this.
  16. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    And in case anyone was wondering - there are significantly more screws connecting the lower Aliner outer wall than there were in the old arrangement.
  17. Sjm9911
    10,628
    8,010
    Look great.
  18. S4nsc
    S4nsc Member
    90
    55
    Jan 30, 2021
    St Augustine, FL
    That looks great. Good work!
  19. Hilldweller
    Hilldweller Well-Known Member
    664
    1,156
    Mar 2, 2021
    Hog Waller, GA
    Dovetails ---- router and jig...
    ...just sayin'...
  20. WrkrBee
    6,539
    3,448
    Unless you have a lot of dovetails to cut, you can have them done in the time it takes to set up the router and jig. You also develop skills that you can't using a router.
