Right turn signal just stopped working
Discussion in 'Road Safety Systems' started by Mad Mac, Oct 6, 2020.
  1. Mad Mac
    Mad Mac New Member
    Aug 5, 2020
    New Jersey
    New to pups, have a 2013 flagstaff my TV is a 2010 ram 1500 2w. On our last trip we left and all light worked fine. When we did our light check to return the camper right (pass side) would not flash. all other lights on camper and truck work fine. I new i cursed myself as my wife and I had just commented on this being our first catastrophe free trip :)
  2. WrkrBee
    4,425
    1,996
    Bulb?
  3. BikeNFish
    BikeNFish Well-Known Member
    3,572
    2,404
    Apr 24, 2017
    Maplewood, MN
    Yup. Check the bulb first.
  4. eoleson1
    eoleson1 Well-Known Member Gold Supporting Member
    3,094
    1,275
    Jul 5, 2011
    Macomb County Michigan
    Did both brake lights work?
  5. tfischer
    tfischer A bad day camping beats a good day at the office Gold Supporting Member
    4,144
    1,615
    May 21, 2014
    Swap the two bulbs (left and right). If the problem moves to the other side, buy a new bulb. If not, wiring issue with the green wire that feeds the right brake/turn light.
  6. KeizerTrailer
    KeizerTrailer New Member
    19
    Aug 31, 2020
    Keizer, OR
    My bet is the wiring. If any of you have seen the wiring done from the factory. :shocked:
    rdk59 likes this.
  7. Mad Mac
    Mad Mac New Member
    Aug 5, 2020
    New Jersey
    Thanks, I did test truck plug and all good. Ill try the bulb but it lights just doesent blink
    flingwing1969 likes this.
  8. A-Ranger12
    A-Ranger12 Active Member
    225
    141
    Feb 25, 2020
    Western NY
    Try wiggling the connector between the truck and trailer. That fixed an intermittent connection on our rig.
  9. Bowman3d
    Bowman3d Well-Known Member
    890
    392
    Apr 13, 2015
    LaLa land (SoCal)
    If you disconnect the tv do the turn signals work on the tv? I’m thinking you have a bulb out on the truck.
  10. neighbormike
    2,878
    2,733
    Oct 6, 2012
    WI
    Not sure on Dodge/ Ram, but check fuses on your truck. GM has separate fuses for trailer lights (tail, lt turn, rt turn, etc).
    Edit: just noticed you said it was good at the trailer connector, so disregard
  11. flingwing1969
    flingwing1969 Active Member
    533
    103
    Jul 6, 2013
    It is a two filament bulb - one filament could be burned out (the brake/blinker) and the other could be just fine (the tail light).
    Bowman3d, tfischer and neighbormike like this.
  12. Jimbow
    Jimbow Well-Known Member
    1,609
    203
    Nov 30, 2012
    Corrosion was the culprit when it happened to me. A spray can of electrical terminal cleaner and I was good to go.
  13. Snow
    11,033
    1,679
    Start with these in order..
    Bulb
    Light ground point
    Trailer connector plug, could be corrosion on the turn signal lug.
    Truck fuse
    Should be quite easy to figure out..
