Roo or Shamrock Owners - How to Switch to DC
Discussion in 'PopOut (Hybrids)' started by JunkyBurrittos, Sep 24, 2019.
  1. JunkyBurrittos
    JunkyBurrittos Active Member
    357
    90
    Mar 18, 2017
    Central MA
    image.jpg image.jpg Please help me make sure I’m not missing anything. When I’m not plugged into shore power, should my DC automatically kick in? Or is there something else I need to do? My control panel flashes four lights (fully charged) for about a tenth of a second and goes to nothing. All 4 lights are constant when on AC. I also have a battery disconnect knob and I’m not sure if I’m supposed to use that whenever going DC or if that is an emergency shut off.
    The previous owner said he brought the battery in every winter and trickle charged it but maybe it’s a goner. My next step if left to my own devices is to take the battery in to be tested. I hope it’s not an inverter issue! I appreciate any advice!
  2. GalsofEscape
    GalsofEscape Active Member
    741
    199
    Nov 26, 2013
    Maryland
    you do not have to do anything to switch to DC, if you have no shore power, the battery will supply power to the battery powered stuff - works the same as a popup in that regard. The battery cut off switch is just a battery disconnect. You should use it when you store the camper to prevent the parasitic power drains from draining the battery (like the CO detector) - would be like you simply taking the battery cable off of the battery to disconnect it. There is a caution- I have read some have reported that a factory installed battery disconnect does not necessarily cut all DC power to the entire trailer like you think it should. things like the tongue jack may still be powered if it is wired directly to the battery.
    it may be a good idea to have the battery checked. mine does still register power on the control panel when i don't have shore power plugged in.
    JunkyBurrittos likes this.
  3. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    Thanks Gals. Out of curiosity, which way (in or out) is to shut down and which way is connected? I was kind of afraid to play with it not knowing what it does. I guess I could just mess with it, just curious how it works on yours. Trying to remove as much user error as possible. Lol.
  4. bheff
    bheff Well-Known Member
    960
    468
    Feb 24, 2011
    NW Arkansas
    Unplug from shore power and turn on a light. If it turns on then the battery disconnect isnt disconnected. If it doesnt turn on it is disconnected. Move the switch in the opposite direction.
  5. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    Okay that was easy, out is on. Got it! My battery only had 1/3 power though and I’ve had it plugged in for days. I guess I need to leave it in the on position in order for the inverter to charge it? And if I’m on shore power it will charge but not deplete? I’m dry camping this weekend and need to get this figured out. Thank you!
  6. theseus
    theseus Centerville, OH
    2,869
    418
    Feb 6, 2007
    Centerville, OH
    Put it on a real battery charger. The camper converter may charge it but will not do a great job. Given the battery’s age, it may be a goner though.
  7. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    Camper’s a 2013 and he replaced the battery maybe three years ago. I’ve got to be able to keep charging this while off the grid and it would be way easier to just plug the camper into the generator although maybe that’s not the most efficient.
  8. SteveP
    SteveP Well-Known Member
    1,530
    421
    If you have a good 3 or 4 stage charger, 10 to 15 amps, it will stir the acid in the battery and may reduce the sulfation on the plates giving you a deeper charge while at home. Then in camp you can plug into the genny to maintain the charge while camping.
  9. bikendan
    bikendan Active Member
    516
    33
    Feb 26, 2012
    Just to clarify, the trailer has a CONverter, not an INverter.
    All RVs come with CONverters, few come with INverters. Roo/Shamrock hybrids have factory Converters. An inverter would be an aftermarket install.
  10. RockyRoo
    6,538
    151
    Jun 8, 2012
    Also remember that in order to charge that switch will generally need to be pulled out (on) to charge the battery
  11. VTRailroadguy
    VTRailroadguy Active Member
    216
    60
    Aug 19, 2015
    Northwestern Vermont
    Yeah, if the battery disconnect was off it essentially cuts your battery from the trailer so it won't charge through the converter. Leave it on when you are charging and turn it off when you are 100%. It's designed to prevent parasitic draw on the battery while sitting unused.
    JunkyBurrittos and theseus like this.
  12. GalsofEscape
    741
    199
    Nov 26, 2013
    Maryland
    and to add to bikendans post (in a not so technical way)-----
    a converter takes ac power (the shore power) and changes it to dc power. the converter will recharge the battery when you have shore power and run the dc stuff - like the lights and water pump.
    an inverter takes dc power and changes it to ac power - so you can run ac equipment from a battery source - like a television (but may not run these items for very long unless you have a big battery bank).
    have a great trip this weekend.
    Sjm9911 and JunkyBurrittos like this.
  13. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    Yup. That’s what I meant. Thanks for calling me out lol.
  14. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    Got it! Thank you.
    Hey on an unrelated note, I think you need a cat pajama photo. Shelmily’s going to think you’re impersonating him. [8D]
  15. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    TY Gals! Meeting up with Portal Peeps so I’ll be in good hands for anything I haven’t figured out ahead of time. :)
  16. GalsofEscape
    741
    199
    Nov 26, 2013
    Maryland
    nice - The Vermont Fall Foliage rally this weekend? They will certainly get you squared away; a great group
  17. VTRailroadguy
    216
    60
    Aug 19, 2015
    You all are going to have to wait for the real thing!
  18. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    Oh man! Keep the crowd wanting more! [LOL][LOL]
  19. JunkyBurrittos
    357
    90
    Mar 18, 2017
    Central MA
    Yes I think I have poor Jimmy’s weekend planned. o_O
