Roof AC is always running?
Discussion in 'Heating / Cooling Systems' started by Rhconcepts, Jul 19, 2020.
  1. Rhconcepts
    Rhconcepts Active Member
    615
    100
    Oct 1, 2015
    Blaine MN
    I just installed a Coleman Mach 3 PLUS. I installed a Coleman-Mach 08-0059 Deluxe ADB Ceiling Assembly 9430D-715 for the inside.
    Question: do they make a inside unit that turns the fan off when it hits a set temp? The fan in mine always runs and I see another brand turns off but doesn’t fit my Mach 3
  2. nineoaks2004
    8,244
    3,689
    Dukes, Fl
    Every one I have had runs all the time
  3. jeeper88
    jeeper88 Let's go Camping and Jeepin
    901
    70
    Apr 24, 2011
    Ocala,FL
    mine runs all the time also
  4. Sneezer
    2,353
    1,205
    Yes, RV ones run all the time in a pup. Any of the roof ones with the on board controls operates the same.
  5. eoleson1
    eoleson1 Well-Known Member
    3,034
    1,231
    Jul 5, 2011
    Macomb County Michigan
    Mine runs all the time too. I've read that you can rewire it to a thermostat, but that seemed like way more trouble than it's worth.
  6. Eric Webber
    Eric Webber Active Member
    311
    199
    Jul 7, 2018
    Montreal, Quebec, Canada
    I have a cheap thermostat that is connected to the power outlet. It just kills power when the temperature falls below a certain threshold. Nothing expensive and no wiring at all.
    but, the compressor surges on whenever it kicks back in, making it only useful when on a bigger power post. Pops the breaker at home (I use a dedicated 20a plug for the AC)
  7. Pdxglocker9mm
    Pdxglocker9mm New Member
    May 24, 2014
    I have a TT now not a pop up.
    BUT in the TT the ac Fan running all night was annoying. I installed a thermostat and the converter assembly that converts the knobs to a relay assembly that the thermostat controls. Best $125 bucks spent that included 9’ wire a digital coleman 12v thermostat, and the conversion kit. Install was easy enough. Now it works like a home a/c. The thermostat i got turns on 1 degree above set temp and turns off 1 degree below set temp.
    eoleson1 likes this.
