Roof damage
Discussion in 'Roof/Floor Repair & Maintenance' started by ericgregoire, Feb 21, 2017.
  1. ericgregoire
    ericgregoire Member
    140
    Jul 10, 2012
    Ottawa - Canada
    So, we got a lot of snow here this year (Ottawa-Gatineau area). Just last week we got 45 cm (18 in) of snow. Well I forgot to remove the snow from my temp shelter and it collapse on the roof of my pop, making a dent in the roof. Any recommendations on how I can fix that? The pop is a 2006 Jayco 1006. In the meantime the pop is now in the garage to avoid any water damage.
    Thanks
  2. rjhammetter
    rjhammetter Husband, Dad, Engineer & Camper
    254
    95
    Mar 1, 2016
    Wisconsin
    Eternabond is a quick and dirty fix. Even though it's far from glamorous, I used it permanently on a quarter-sized hole in our roof. 4" wide rolls are pretty pricey but totally effective.
  3. jmkay1
    5,798
    2,612
    Ouch! Sorry no help on the roof. My old 90's Jayco had an aluminum roof and even though it had many dings it never broke through. It looks like your roof is composed of something different. Good thing you caught it now.
  4. Barefoot311
    Barefoot311 Member
    177
    22
    Sep 22, 2011
    How big is the area in diameter? Eternabond will seal it but is going to leave a low spot for water to pool. If the area isn't much more than a few inches, I would recommend a square metal cover. Can be cut out of aluminum that is thin and light and then Dicor around the edges and over the screws.
  5. Jimbow
    Jimbow Well-Known Member Gold Supporting Member
    1,574
    186
    Nov 30, 2012
    It seems small. A little Eternabond and dicor may be all you need.
    The views expressed may not be mine in five minutes.
  6. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,702
    May 8, 2011
    Florida by way of WV and MD
    ^^^^^ This ^^^^^^^
    I wouldn't over think it. Just fill in the little gap and slap some Eternabond on it. Done.
    At the end of the day, it's just a roof and nobody ever sees it when you're camping. I'm sure there are ways to do it more attractively, but this way is perfectly effective.
  7. Arruba
    Arruba Active Member
    418
    165
    Nov 28, 2014
    Central Oregon
    If you choose the Eternabond route, you can usually buy it by the foot at a good RV supply store. At least you can in my neck of the woods.
  8. Jeepguy93
    Jeepguy93 Active Member
    503
    36
    Mar 30, 2014
    MA
    Use a filler to level it. Jb weld worked on my aluminium roof. Then seal or tape over it however you want.
  9. ericgregoire
    ericgregoire Member
    140
    Jul 10, 2012
    Ottawa - Canada
    I have found something similar, that I can purchase here in Canada, it's called Rexoseal.
    What I will probably be doing is remove a square of ABS around the damage area, replace the foam underneath, cover it with a large square of ABS, then seal it with a patch of Rexoseal.
    Thanks for your comments.
  10. world traveler
    world traveler Active Member
    275
    25
    Oct 23, 2015
    I used sikaflex, which was recommended by starcraft for the roof fix for my trailer. I had a small dent and just filled it in with sikaflex 221 and spread around with soapy water to smooth it out.
  11. Fasttimes7
    Fasttimes7 Member
    115
    Sep 7, 2014
