Roof fan.
Discussion in 'Wiring' started by utah steve, May 14, 2016.
  1. utah steve
    utah steve New Member
    74
    Apr 17, 2016
    I need to install a ceiling fan. Can I connect wires to 12V portable fan/ light? No ceiling light.
    Sent from my SM-T330NU using Tapatalk
  2. utah steve
    74
    Apr 17, 2016
    I mean to the plug,for the fan/light.
  3. Dubbya
    6,130
    76
    Aug 2, 2011
    Steinbach, MB
    I installed a vent fan and tapped into the light circuit, drilled through the wood frame around the roof vent opening, drilled through a steel cross member in the ceiling, pushed a coat hanger to make a channel through the Styrofoam in the ceiling then pulled the wires through the channel with a fish tape.
    Alternatively, if you've got ceiling lights, there will be a pocket with a pair of wires that runs up the tenting behind the galley or in the corner nearest the galley. You should see some wire nuts inside the pocket at the top or bottom so you can tap in there.
    Is that what you're asking or do you not have ceiling lights at all?
  4. mrshanson
    mrshanson New Member
    May 4, 2013
    We are also looking to install a roof fan. We have a Fleetwood SantaFe with ceiling lights on both ends. Is there anything we should be looking out for? We currently have no vent in the roof and will have to cut a hole and start from scratch. Is there anywhere to go to get schematics of the roof so we don't cut anything important?
  5. kitphantom
    12,827
    1,880
    @mrshanson
    Are there 4 tiny buttons on your ceiling, in a square pattern? On our 2010 Coleman, those marked the location for an optional vent.
