Roof rebuild
Discussion in 'Roof/Floor Repair & Maintenance' started by todd jones, Oct 10, 2020.
  1. todd jones
    todd jones Member Silver Supporting Member
    35
    Aug 15, 2020
    Hello all, I purchased a 2004 Fleetwood Sequoia a little over 2months ago. I thought I had found all the damage from the A/C leaking. It is now a complete rebuild while the roof is still attached. I wish I had a building.
    I found water dripping from foam once I got to it. so this is why I decided to fully rebuild. This roof has no wood other than the inside round over part the wiring is attached to. I’m replacing the sides with 3/4” plywood and the 1/8” wood utility board found at Home Depot.
    I also have had 11/2” x 3/4” thick aluminum welded to go where the A/C goes. The longer runs will go under the A/C bars on the ceiling. I will thru bolt to the roof where it will be attached to 11/2” aluminum tubing. The roof should not sag at all.
    I was hoping to glue the 1/8” utility board to the foam first the glue that to the roof. However I have noticed the foam runs in a different direction. I realize why this is. My question is will it be okay to do it my way?
  2. todd jones
    35
    Aug 15, 2020
  3. todd jones
    35
    Aug 15, 2020
    I have another question fir the inside seam. This seam runs front to back with the A/c having to seal with this seam in the way. Does anyone do anything with the inside to help seal? And possibly taking the seam off and doing something different?
  4. steve7-4
    steve7-4 'I'd rather be camping'
    154
    Aug 26, 2014
    Northeast Illinois
    I am wondering how you are going to rebuild the sides with 3/4 plywood. I see plywood that is 8 feet long. Are you sides less than 8 feet long? How will you join the plywood if over 8 foot? I will be doing the same over the winter or next spring.
    Thanks,
  5. todd jones
    35
    Aug 15, 2020
    No sir it is a 15’ box. I used e6000 this glued the two ends. On my pup the 3/4” plywood went into a track on the metal piece. I then used contact cement to adhere the 1/8” utility board to the 3/4” plywood. That gave it strength. I then used e6000 behind the 3/4” and glued it to the metal roof fir added strength. That will give me the support I want fir my set up for holding the A/C up properly. I will post pics so you can see once I get that far.
  6. todd jones
    35
    Aug 15, 2020
    6C8452A0-9F1C-4AEA-BE0E-511D1826E6D0.jpeg CE30BC7F-2049-4DFC-B257-3FBFCA1EF356.jpeg
  7. todd jones
    35
    Aug 15, 2020
    I used locative pl to bond the foam to the 1/8” and to the roof. Someone on this forum suggested it and it was a great suggestion.
  8. todd jones
    35
    Aug 15, 2020
    Loctite pl
