Roof repair
Discussion in 'Miscellaneous Repairs & Maintenance' started by Shaun., Aug 23, 2018.
  1. Shaun.
    Shaun. New Member
    Jun 25, 2018
    I have a 92 American Sequoia. It’s has a soft spot in the ceiling above the back light due to previous water damage. Would this be a simple fix of tearing out old material and putting in new supports? It seems a cross beam must be weak because I push down on it from the outside and there is a bit of saggging going on. And recommendations? Thanks
  2. joet
    4,674
    915
    Yes this is repairable, but you will find that when you start tearing the roof off a lot more rot.. but repairable
  3. WrkrBee
    WrkrBee Well-Known Member
    2,440
    934
    Welcome to the Portal from South Carolina.
  4. Shaun.
    Shaun. New Member
    Jun 25, 2018
    This is my ceiling. Do you think putting a piece of 1/8 in plywood over this will give the ceiling integrity or should I run some type of cross beam from one side to Other.
    OTE="joet, post: 1229908, member: 28956"]Yes this is repairable, but you will find that when you start tearing the roof off a lot more rot.. but repairable[/QUOTE]
