Roof support safety supports.?????
Discussion in 'General Camping Discussion Forum' started by squid, May 9, 2016.
  1. squid
    squid Member
    28
    Jul 7, 2011
    A person in the campground I was in cranked up his roof and then put 2x4's next to each roof support(cable tracks). Later I went over and asked him why he did that. He said that he did it as a safety measure in case a cable gave way while set up and someone was in camper, thus keeping the roof from coming down. Said he cut them about 1 inch shorter than his fully raised roof. He also said some people do the same thing only to take some tension of the cables. Said they raise the roof and put 2x4's in and lower roof just on top of boards. Helps take the load of cable system. HAs anyone heard of this? This is the first for me.
  2. JustRelax
    JustRelax Well-Known Member
    1,006
    207
    Feb 20, 2013
    Indianapolis
    My PUP had a metal support that went around the lift rail - one per side. Put them on opposite corners. Yes the purpose is to keep the lid from crashing down if a cable snapped. My door wouldn't latch together if I just relied on the catch rails.
  3. Dubbya
    6,129
    64
    Aug 2, 2011
    Steinbach, MB
    Many campers come with one or occassionally two of them but they're metal and slide over the lift post. You should only need one safety support on the lift post diagonal to the door since the door frame itself will prevent the roof from collapsing.
    2x4's will work but I'd highly recommend that you cut a few lengths of 1-1/2" ABS pipe and store them in an old lawn chair bag to use in the event that a cable snaps at the CG (Camp Ground). You'll just need to measure the distance between the top of your walls and the edge of your roof then cut the pipes accordingly. They're light, more than strong enough and they're impervious to moisture. Besides, they fit nicely inside the flaps that cover most lift posts so they're hardly noticeable.
    In the event that a cable snaps (even if you're alone) you can raise the roof about 3", insert a 6" length of pipe beside the collapsed post, crank up to 9", insert a 12" pipe, then 18", 24", 36" and 44" (or your max height). Reverse the process when lowering the roof and fix the broken cable ASAP.
    I got through our first season that way and have kept these pipes on hand in the storage compartment ever since. They're also very handy when replacing cables or adjusting the roof height.
    Here's what I'm talking about: http://www.popupportal.com/index.php?topic=56892.msg562143#msg562143
    myride and firepit like this.
  4. Nandy
    Nandy Active Member
    2,255
    Mar 29, 2010
    If your camper has a solid door then you dont need those. You can buy them but they are very expensive. Dubbya has good advice.
  5. jmkay1
    5,488
    2,275
    I think it wouldn't hurt anything and may be nice to have. Here is my experience with my old jayco. I did have one cable snap on my lift however because the other cables were still working without a problem and the door was in place the whole roof didn't fall, only just that corner and it fell only by like three inches. Yes, kind of scary knowing the pressure put on all three other corners, but it held up threw the night until my brother found a tree to support the fallen corner for tge trip. So I'm sure some lift systems have kind of like a fail safe to prevent the entire roof from crashing, but I'm sure there can be a situation where it could happen.
  6. kitphantom
    12,167
    1,188
    Depends on the make, model and year. Our old, 1984 Palomino had external lifter arms, so no cables to worry about. Our 2010 Coleman, as with many years of Coleman pups, had 4 separate cables, and a solid door meant to support the roof if things went south.
    I've seen 2x4s, PVC or electrics conduit as supports.
  7. Wecamp04
    Wecamp04 Member
    161
    Sep 14, 2014
    TN
    I had an 84 model pup I did this to roof fell once while camping ,no one hurt but sure got your attention. Never figured out what happened it cranked right back up next trip had 2x4 installed at each corner.
  8. silvermickey2002
    4,760
    534
    Sep 11, 2008
    Morris County, NJ
    Coleman/Fleetwood pups really don't need supports since they have a one piece door. Also they have four cables, one for each lift post.
    Question for the OP, what make pup do you have?
  9. squid
    squid Member
    28
    Jul 7, 2011
    Thanks for all the great info. Did not fully understand the make up of the lift system I have a 2008 Fleetwood Santa Fe and I learned a lot about the lift system here. Again thanks for the info. Charlie
  10. Chaloune
    Chaloune New Member
    22
    Apr 23, 2020
  11. firepit
    firepit Well-Known Member
    692
    783
    Feb 26, 2020
    Nebraska Go Big Red
    turbo lab1 076.jpg View attachment 61781 View attachment 61781
    That is what i did on my old coleman...i used 2x2 lumber and made the notch just like that....my cables were so stretched i had to make mne a little long to push the roof up or the door would rub the roof edge....its a cheap hack that gets the job done
  12. Running Wolf
    Running Wolf Member
    78
    May 11, 2015
    Edwardsburg Mi Irons Mi
    My step father purchased a 2015 that has 2 of them. One for each side, front and back
