Roof support safety supports.?????
Discussion in 'General Camping Discussion Forum' started by squid, May 9, 2016.
  1. Old ackpacker
    Old ackpacker Member
    88
    70
    Sep 4, 2017
    Southern Illinois
  2. tombiasi
    6,008
    1,527
    Cables can break
    Thox Spuddy likes this.
  3. Blue411
    Blue411 New Member
    26
    Jul 4, 2020
    We bought the wood, I think 2x2, and did the same thing. Well, we have 2 posts plus the door. Not sure if the wood posts should both be on the opposite side of the door.
  4. Thox Spuddy
    Thox Spuddy Active Member
    116
    62
    Apr 24, 2011
    Wisconsin
    I stand corrected, apparently quite common after doing a little research.
  5. lynnmarie0123
    lynnmarie0123 Active Member
    353
    74
    Jun 19, 2020
    im new to pupping. It seems odd to me that theres only two manufacturer provided metal support bars that fit over the actual lifters. Seems like there should be 4 - one on each lift rail on each corner???? Seems a bit of a liability if one corner snaps down while someones inside.
  6. AMC
    AMC Member
    48
    Apr 7, 2020
    South Georgia
    Reading this made my night!! THANK YOU! No issues with mine but well meaning brother tried to scare me. LOL
  7. silvermickey2002
    4,789
    573
    Sep 11, 2008
    Morris County, NJ
    Just be sure to perform routine maintenance on the lift system. If you ignore it, it will fail! Every year I spray all the pulleys with silicon. Every other year I clean and re-lube the whiffle tree. Two or three years ago I cleaned the crank assembly (clutch system). It's better to find an issue when at home doing routine maintenance then have a major issue at the campground.
