rooftop ac?
Discussion in 'Miscellaneous Repairs & Maintenance' started by countrymom, Apr 18, 2018.
  1. countrymom
    countrymom Member
    32
    Sep 22, 2014
    has anyone or can you install rooftop ac unit in the rooftop vent?
  2. xxxapache
    3,077
    1,069
    Yes, if the vent hole is 14 x 14.
  3. BikeNFish
    BikeNFish Well-Known Member
    3,336
    2,247
    Apr 24, 2017
    Maplewood, MN
    I am guessing that you will need additional supports.
    NTL1991 likes this.
  4. Texas Tara
    Texas Tara New Member
    Apr 3, 2018
    Our 86 Coleman has a foam core roof lined with aluminum on top and a thin 1/8" board on both sides of the foam core. To support the AC, they used a single brace that spans the inside, under the whole roof system, and covered it up with a tin panel painted white. The brace is supported by large screws on the outside, screwed into the brace on the inside. Doesn't really look bad and you don't notice it. The power cable can be run under that tin cover as well.
  5. roybraddy
    roybraddy Well-Known Member
    2,305
    848
    Mar 23, 2016
    King George, Virginia
    This is what the inside brace looks like for roof a/c install... Hopefully your 14x14 inch hole is centered on the roof and not off to one side although it probably would not make any difference.
    google image
    Roy Ken
