Rotten flooring under the lift mechanism.
Discussion in 'Roof/Floor Repair & Maintenance' started by Fern, Jan 11, 2020.
  1. Fern
    Fern New Member
    Aug 8, 2017
    2012 Starcraft. We are thinking we will need to replace the entire flooring. The section under the lift is completely rotted so the lift can’t raise the roof all the way. We are concerned that once we remove the lift we won’t be able to get it back on the correct way. We have found water rot on other sections of the floor. Is it time to sell as is and start over?
  2. bheff
    bheff Well-Known Member
    1,504
    920
    Feb 24, 2011
    NW Arkansas
    Totally depends on what you are comfortable doing. If you decide to repair/restore take a lot of pictures and notes. Label as much as you can.
    Good luck either way
  3. Raycfe
    17,005
    2,587
    Whether its the winch or one of the lifting post, any section of the floor can be replaced. The repair section needs to be well supported. A sheet of steel under the post or winch would be super strong.
    EmilyW likes this.
  4. kennedyma
    kennedyma Member
    87
    65
    Oct 8, 2018
  5. EmilyW
    EmilyW Member
    74
    18
    Jan 12, 2020
    Knoxville
    How would you go about doing this? We are in the middle of a full floor gutting, and wonder what enhancements we should do while everything is bare and exposed.
    cabnboy likes this.
