Rubbermade Action Packer
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by bigphil298, Jun 9, 2012.
  1. bigphil298
    bigphil298 New Member
    22
    Jun 2, 2012
    I just purchased one for a front storage on my pup. My question is how are they at keeping water out when sitting and driving. Any information would be great
  2. JeepMama
    JeepMama New Member
    2,424
    Jun 10, 2011
    Hmmmm, that looks like it would be a great Father's Day gift... What size did you get 48 gallons?
  3. campfreak
    campfreak Active Member
    2,023
    25
    Jan 13, 2011
    We have a couple of them, and they keep rain out pretty well when sitting. I've never had a problem. I'm not too sure about towing, I don't think I have had it outside while towing.
  4. bigphil298
    22
    Jun 2, 2012
  5. Shuswap
    Shuswap New Member
    481
    Jan 15, 2012
    We use 2 on the cargo tray of our E1 - one for firewood and the other for my camp and repair stuff. No problem with water intrusion while at camp but not yet certain about when in transit. They were exposed to heavy rain last week end. For my camp and repair stuff, I keep everything in smaller containers just in case.
  6. silvermickey2002
    4,778
    557
    Sep 11, 2008
    Morris County, NJ
    I've had one on the "A" frame for a few years and no problems so far.
  7. Bob Bourgeois
    Bob Bourgeois "I'd rather be camping"
    95
    May 30, 2012
    Green Island, NY
    How did you attach these to a frame, or any other location for that matter? Rachet straps or bungie cords?
  8. Shuswap
    Shuswap New Member
    481
    Jan 15, 2012
    The Action Packer has knockouts for anchoring bolts in each corner. Our 48 qt is anchored to the cargo tray as it contains camp and repair gear (theft protection). The 32 qt size used for firewood is not anchored.
  9. BajaPup
    BajaPup New Member
    865
    Apr 19, 2012
  10. silvermickey2002
    4,778
    557
    Sep 11, 2008
    Morris County, NJ
    In this pic you see the 4 bolts going thru the bottom.
    In this pic you see the box is mounted on top of 2x4's painted black. I used 4 2x4's cut to fit between the angle iron supports. Two stacks with 2 2x4's.
  11. BajaPup
    BajaPup New Member
    865
    Apr 19, 2012
    If you decide to bolt down an ActionPacker, use fender washers to prevent the bolts from pulling through the plastic.
  12. Bob Bourgeois
    95
    May 30, 2012
    Green Island, NY
    Nice. Couldn't see the mounting system from the original pictures. I'm looking for more storage options because we went from a Dodge Caravan as a TV to a Nissan Xterra. I could get alot more in the van, but it was time to trade up.
  13. brianbigdogsmith
    brianbigdogsmith Camp more Camp more often
    822
    Feb 20, 2012
    Melviindale MI.
    I removed the 20 lb propane and made a deck out of p1-11 and put a 6 locking tote on mine and use ratchet straps to hold it to the tongue
  14. Tacoma_Jim
    Tacoma_Jim Member
    555
    Oct 16, 2011
    Oregon
    I screwed one to my rear bumper with self-tappers and put my sewer hose in it. With it being on the back it doesn't get water driven into the seams during travel. I suppose it could have been attached with straps, but I put plastic gutter for sewer hose support in my bumper.
  15. bondebond
    bondebond New Member
    2,079
    17
    Aug 14, 2008
    To keep water and dust out of mine, I used adhesive-backed foam weatherstriping for windows and put it on the lid to make a really good seal. I just followed the depression where it rests on the container. I field tested it in extreme dust situations and also through a number of rains without any signs of intrusion. I just had that much more peace of mind with that weatherstripping in place.
  16. BajaPup
    BajaPup New Member
    865
    Apr 19, 2012
    I've been meaning to do that before the next trip. Thanks for the reminder.
  17. 98Roamer
    98Roamer Member
    87
    Oct 5, 2012
    I looked at the Action Packer for the roof basket. I read where people have used the black gasket making sealant that comes in a tube to created a water and dust proof seal. The squeeze the sealant out the rims, line the lid rim with wax paper, put the lid on it and clamp it down. Wait for it to cure, remove the wax paper and you have a custom formed rubberized waterproof seal. I'm not sure how durable it would be under heavy abuse.
    I ended up going with a Pelican 1600 case instead of the DIY Action Packer.
  18. BajaPup
    BajaPup New Member
    865
    Apr 19, 2012
    I believe you're referring to RTV (Room Temperature Vulcanizing) silicone. I guess that'd work, but it seems like it'd be too stiff. Weatherstripping will be good enough for my uses.
    No doubt a Pelican case is much more rugged and better sealed than any Rubbermaid container.
  19. PupNut
    PupNut New Member
    26
    Sep 6, 2012
    I have one for my TV to keep tools and emergency gear in. It has sat chained back by the tailgate and not had any issues. I get issues when I actually get water in it. It holds the water in and will rust tools. As long as you keep the inside dry, it should be just fine.
  20. Aladin Sane
    1,102
    130
    Jul 3, 2008
    Iowa
