The canvas is back in place!!
Man, now it feels like a real camper again. After snapping the last pic, I literally fell backward on the bunk and lay there for about ten minutes. So close... so doggone close.
It was overcast yesterday and the battery was at 86% SOC (hadn't yet got it up to 100%), so for fun I threw out the solar panels again to see what the draw was.
I guess it's a good thing I went with the 100AH battery
As you can see, the galley went back in before I replaced the canvas. Unfortunately I got impatient, and flipped it over before the paint was 100% cured. Will have to touch it up near the hinge in the coming days.
Word of warning - if you order the Camco sink drain kit, you will need a longer hose than what's provided for this style of galley. Fortunately my old hose was long enough to survive having 2" lopped off from each end and still work, so I didn't need to order a new one... yet. Most everything tested out great, but for some reason I'm getting a small leak whenever I flip the galley over. I know it's coming from the drain, but that thing should be sealed tight as can be. I guess I either messed up on the plumber's putty, or didn't put enough sealant on the threads. That'll get fixed before I install the cabinet doors.
Speaking of, I cut and routered out nearly all the wood to replace the cabinet doors. The sheet I bought covered all but one door. I was gonna leave it be, but now I'm thinking I want to redo the drawer faces as well... The blonde wood I used only cost $20, so... might as well?
Other odds and ends: New fire extinguisher and bracket!
New "t-style" level!
And finally, the upgrade-that-I-wouldn't-name in the last post - dual LP tanks!
I still need to make or buy a line that goes from the regulator to the hard line, but to me this was the hard part. Now I need a cover to hide the mismatched tanks...
