Running lights stopped working
Discussion in 'Lighting, Interior and Exterior' started by Orchid, Dec 2, 2016.
  1. Orchid
    Orchid Sharp Shootin' Grandma
    5,585
    2,399
    May 8, 2011
    Florida by way of WV and MD
    All of our exterior lights were working up until last trip. Hooked up, and on our pre-trip check, the running lights and one brake light were not working. Fixed the brake light by replacing a blown fuse. Went ahead with the trip, as it was only a couple of hours away and daytime travel.
    Now that we're home, trying to figure out the problem with the running lights. Brake lights and turn signals work fine. We plugged it in to SIL's truck at camp site to test and same problem, so it's a problem on the trailer, as opposed to the tow vehicle.
    Any advice on where to start?
  2. nineoaks2004
    7,745
    3,397
    Dukes, Fl
    first thing to check is the ground wire, next check the wire going to the running lights for good contact from the plug
  3. JT2
    JT2 Member
    710
    24
    May 20, 2008
    Yep. This sounds like something simple; finding it is the problem.
    Clean each pin on the trailer connector very carefully, getting all the corrosion and crud off the pins.
    Connect firmly to TV , turn on lights. Markers should (might) work.
    If not, jiggle the wire harness at back of trailer plug to see if it's a loose wire inside the connector. (If so, lights should flicker as you jiggle.)
    If still no joy, check the ground connection to the trailer frame.
    Identify the appropriate wires (from the wiring chart) and check them visually from the trailer connector as far as you can. Look for nicks, breaks, loose connectors, and other obvious problems.
    Do NOT start disassembly, socket checks, etc until you've eliminated all the simple stuff at or around the front of the trailer.
    Good luck; keep us posted on what you find.
  4. unclemark
    unclemark Overland Park, KS
    377
    41
    May 15, 2014
    Overland Park, KS
    When I installed a seven-pin adapter on my tow vehicle, part of it plugged in "permanently" into the existing 4-pin connector. About a year afterward, I began intermittently losing lights. By this fall, the lights were utterly unreliable, even though I'd spent a year trying everything short of rewiring both vehicles. Well, there was another thing I didn't try: unhooking the four-pin adapter and cleaning all those pins. I finally tried that this fall, and I've had no more problems.
  5. Orchid
    5,585
    2,399
    May 8, 2011
    Okay Kids, I put this question up before we left for vacation so I'd have some leads to try when we got home.
    Tuesday is the day that we address this problem. Thanks to those that offered suggestions. Giving it a bump in case anything has anything to add before we go total Griswold on it. [;)]
  6. SteveP
    SteveP Well-Known Member
    1,599
    456
    Indicates it's a trailer problem but
    say's slow down a little.
    Take a look at these diagrams.
    http://sloanbooks.com/wiring/7-pin-rv-plug-wiring-diagram
    Check the current at the top left pin to determine if you have power to the running lights from the truck. If yes, then it's definitely a trailer problem.
    If no then you need to start working backward on the tv. You should find, near the back of the TV, something like this:
    http://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Curt/C55336.html. Check both the input and output sides of the circuit box to see if you have power on all circuits. If you have power on the input but not the output you probably need to to replace the box. If no power on the input I'd start looking for another fuse.
  7. Orchid
    5,585
    2,399
    May 8, 2011
    Thanks for the advice! We plugged it into two different vehicles with the same results ... my van, and my SIL's truck.
    I will take a look at the diagrams for sure. We did check all the fuses in the camper. Could it be a fuse in the TV? I've never thought about checking those.
  8. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    Probably 90% of these kinds of problems are because of a bad ground somewhere.
  9. SteveP
    1,599
    456
    The running lights, brake lights and turn indicators are fused from the tv. The don't interact with the camper systems at all.
  10. Orchid
    5,585
    2,399
    May 8, 2011
    I apologize for sounding argumentative, but a blown fuse in our camper fixed the brake light that was out. I know that for 100% fact because I did it myself.
    A bit of Googling has me thinking you are spot on.
  11. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    Then your trailer is wired incorrectly. There should be no fused wires between the trailer receptacle and the light fixtures themselves. The manufacturer is required by law to wire the trailer's signalling capabilities independent of its other 12v systems.
  12. Orchid
    5,585
    2,399
    May 8, 2011
    This is not good news. However, I suspected as much when we could turn the cargo light switch into a roof light switch by reversing two wires.
  13. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    *facepalm*
    Neither of those have anything to do with signalling. And it's entirely possible to change the source of power from one RV fixture to another by swapping wires at the source.
    I think I've said this recently on this forum or another, but you should really Google some electrical theory. "Swapping wires" to test things is a very scary way of going about it. Pop-ups burn fast. So fast you'll be looking for a garden hose and it'll turn to ash. Please invest in a decent electrical test meter and the knowledge to use it.
    Also, a garden hose is the wrong way to put out a pop-up electrical fire. Guess I should disclaim that. Keep an ABC extinguisher on board and inspect it regularly.
  14. SteveP
    1,599
    456
    If the fuse you changed that fixed the brake light was in the camper then that definitely points to a ground issue in the trailer. I had assumed the fuse was in the tv.
    When the circuit is disrupted the current will find any possible path to ground, even backfeeding through other circuits. Because both 12 volt systems share a common ground, the trailer frame, when you replaced the fuse you gave the current a new path to ground.
  15. Orchid
    5,585
    2,399
    May 8, 2011
    I told you we are Griswolds ..... [LOL] Never got to it today due to excessive pain. Have emergency ortho appointment Thursday, so the lights are on hold again.
    You probably don't want to know that we left it as a light switch for the ceiling lights for awhile because it was convenient. Now we changed it back to it's original duty as cargo light switch, in case it was any kind of culprit in the running light issues, which doesn't appear to be the case. Still going to leave it as intended.
    Interesting .... It was a fuse inside the camper. What you just said above actually makes sense to me! I get excited when I have a clue what people are talking about. I mean when I'm out of my comfort zone. [:D]
  16. Orchid
    5,585
    2,399
    May 8, 2011
    After dealing with this for a few weeks, we have found the problem.
    I refuse to admit to all the things we did / checked to try to find this problem, as I'm sure it would result in a good laugh to more knowledgeable folks. [LOL]
    I will say that the ground wire from the battery (I think, without going out and looking) was half exposed, so we thought that was the problem for sure. Cleaned some new wire and got it firmly under the metal thing where it belonged. No love.
    Today, after some other interesting pursuits, we decided to check light bulbs, even though they were working for brakes and turn signal. Found a bulb in one of the main taillights with a corroded base and one burned filament. Replaced. Problem solved.
    OH. MY. GOSH! We practically had the entire camper a piles of sawdust and wires on the ground over a stupid bulb. Live and learn ....
  17. JT2
    JT2 Member
    710
    24
    May 20, 2008
    First, good on ya' for tracking it down and figuring it out. Well done!
    Fear not, and file it under "Stuff Happens."
    In my dealership shop days I once watched a highly knowledgeable and reliable technician spend 12 hours taking a car to pieces to track down bizarre taillight behavior. He was our best electrician and followed the book exactly, which required starting the troubleshooting at the battery. He had to remove half the dash and all the seats and carpets to check wiring, connectors, etc. from front to back.
    What'd he find? A shorted double-filament bulb in a brake light...one filament burned out, drooped and touched the other one, causing a disco effect when the turn signals were used. (And for the other shop rats around here, yes, the factory paid the entire warranty claim to the shop because he followed the service procedure as written AND documented every step in writing.)
  18. Orchid
    5,585
    2,399
    May 8, 2011
    Thank you for this! [:D]
    It does make me feel less ridiculous. We had just begun to tear the van (tow vehicle) apart when I decided to check the bulbs. I didn't think it would be a bulb since they were all working as brakes and signals, but just decided to do it anyway. Apparently, they are like a Christmas tree ... one goes out and you're in the dark.
    I put off until tomorrow putting everything back together. We have lots of stuff torn apart on the camper. [LOL]
