Rusted Frame?
Discussion in 'Miscellaneous Repairs & Maintenance' started by JJC1243, Jul 1, 2020 at 2:30 AM.
  1. JJC1243
    JJC1243 New Member
    Jul 13, 2014
    We have a '93 Coleman Destiny Royale. She hasn't been out in a couple years and we are hoping to get her back in good shape for use or resale at some point. My dad had pointed out that the frame needed some welding when we got her 6 years ago, but we forgot to address that unfortunately. At this point, is this something we can have repaired? Where would you go for repairs? We do know a welder. What would you advise? Both underside pictures are from the very front of the trailer frame.
  2. bobinfleet
    bobinfleet Well-Known Member
    825
    332
    Sep 2, 2011
    Hampshire UK
    If you know a welder it should be an easy fix for him
  3. Ductape
    Ductape Well-Known Member
    1,176
    169
    Jun 12, 2013
    I wouldn't go camping until that is welded properly. No point in killing someone. I agree it is perfectly fixable though. Get it done and go camping.
    Sjm9911 and nineoaks2004 like this.
  4. Snow
    10,667
    1,407
    That frame is broken due to stress, not from rust..
    xxxapache and JJC1243 like this.
  5. JJC1243
    JJC1243 New Member
    Jul 13, 2014
    Oh yes! For sure, not going anywhere until it can be fixed. Just glad to know it is fixable!
  6. JJC1243
    JJC1243 New Member
    Jul 13, 2014
    Thank you!
  7. WrkrBee
    WrkrBee Well-Known Member
    3,551
    1,510
    The frame will need to be set straight before welding. Both sides have dropped. The front panel has cracked in two places due to the sides dropping. I would think there are panels / joints / corners inside that have been racked, also.
    xxxapache likes this.
  8. tzmartin
    tzmartin Well-Known Member
    1,097
    499
    Sep 9, 2015
    You might want a new tongue jack as well. The rotation attachment point and ring has worn down a bit.
  9. Jawritch
    Jawritch New Member
    24
    Apr 19, 2020
    Nova Scotia, Canada
    Frame broke in the same place on our 92. Not a bad fix.
