RV fridge DC Operation
Discussion in 'Refrigerators and Coolers' started by ve3tiz, Jul 3, 2020.
  1. ve3tiz
    ve3tiz Member
    52
    23
    Mar 22, 2014
    Windsor, ON Canada
    So after a few days of monitoring progress on propane I decided to shut that power source off and switch to D.C. I do have a pair of newer Deka 6 volt golf cart batteries with 190A and according to the specs on my little fridge it draws 10A on DC so... we'll see if (a) it holds temp and (b) how long before the batteries start to lose power. Theoretically I should be good for 9 hours. We're still in the middle of a heat wave (highs ranging from 90-95) so taking that into consideration as well.
    Brewman likes this.
  2. Sjm9911
    6,916
    4,306
    Dc is not a good choice for the fridge, except when towing it.
  3. ve3tiz
    ve3tiz Member
    52
    23
    Mar 22, 2014
    Windsor, ON Canada
    That seems to be the case from what I've seen the last couple hours!
    Raycfe and Sjm9911 like this.
  4. Anthony Hitchings
    1,229
    571
    Mar 2, 2019
    If its a Dometic 2193 or equal, the problem is that on 12VDC its on 100% of the time - no temperature regulation. Which drives up power consumption.
  5. ve3tiz
    ve3tiz Member
    52
    23
    Mar 22, 2014
    Windsor, ON Canada
    Yes, I noticed that. And in spite of it being 100% on all the time, I could tell right away it wasn't even holding temp as well. So I switched back to propane. Just thought I would experiment.
  6. Sjm9911
    6,916
    4,306
    Propane is best, then 120 volts. 12 volt if your towing. But i used to load the fridge up with frozen stuff or ice blocks if i had room in it. Then its spectacular :D
  7. Raycfe
    17,005
    2,575
    Just to add ....... 12 VDC when towing if your tow vehicle has a working "charge" line.
    ve3tiz and Sjm9911 like this.
  8. Eric Webber
    Eric Webber Active Member
    304
    195
    Jul 7, 2018
    Montreal, Quebec, Canada
    I get less battery draw on my fridge using the 120v setting (through inverter) than on the 12v - and thats despite the efficiency losses due to power conversion.
    I still use propane for my fridge because I want power for other things, but I have enough solar and battery that I can stay in 120v setting indefinitely while parked in my driveway and not using much other power
    when camping, I like to know I can use the air conditioner for an hour or two per day, plus my coffee machine and induction burner. Can’t do all that and run the fridge
    ve3tiz likes this.
  9. WrkrBee
    WrkrBee Well-Known Member
    3,847
    1,666
    I like it when people try different systems and post their real world experience. That means I don't have to.
    Ductape likes this.
