Ryobi Inflator run time
Discussion in 'Tires / Brakes / Bearings / Axles' started by undara12, Aug 22, 2021.
  1. undara12
    undara12 Member
    43
    Mar 25, 2016
    I have a Ryobi P747 inflator. On one page of the manual, it says to run the inflator for 5 minutes and let it cool for 5 minutes before running again. On another page it says 10 minutes on and 10 minutes off.
    I called customer service and was told to run until the inflator cuts itself off and then let it cool for 5 or 10 minutes. Any thoughts on this?
  2. Tarkus
    Tarkus Member
    82
    60
    Aug 15, 2021
    Wyoming
    The manual I just read says..."Allow pump to cool for five (5) minutes after each five (5) minutes of continuous use...."
  3. Sneezer
    2,856
    1,691
    I have that inflator. I have used it a couple times to top off tires, unless the tire is flat, it usually runs 5-10 min. I got mine on clearance for cheap a while back, so I treat it as disposable. I’ll run and abuse it until it dies, at which point I’ll get a Viair one which is far better, although 12v corded.
    Fish N Farm and gladecreekwy like this.
  4. gladecreekwy
    1,561
    2,407
    Sep 25, 2016
    Jackson Wyoming
    When that thing quits get a Viair.
    Fish N Farm and theseus like this.
  5. undara12
    undara12 Member
    43
    Mar 25, 2016
    Yep, that is on page 3. Look near the bottom of page 5. "NOTICE: The inflator is not designed for continuous use. For every ten minutes of inflator use, ten minutes of cool down time is required."
  6. undara12
    undara12 Member
    43
    Mar 25, 2016
    I think the Ryobi is not the best choice if you want an inflator to store, long term, in a vehicle for emergency use.
    I intend to carry it on camping trips for emergency tire use and for using the low pressure feature to inflate the air bags in my white water canoe. I will also use it at home for maintenance of tires including the lawn mower.
    I like not having to worry about where I'm going to plug in the inflator. I had already bought into the Ryobi battery system.
    gladecreekwy likes this.
