Safe to Leave Fridge Running on Propane?
Discussion in 'Refrigerators and Coolers' started by zak99b5, Jun 18, 2020.
  1. zak99b5
    zak99b5 Active Member
    178
    108
    Feb 21, 2019
    I'm finally able to go camping next week! I booked a site at a state campground (no hookups) for Monday to Monday. A couple days during the week we need to go back home.
    Is it safe to leave the fridge running on propane while I'm gone for a couple days? I'd like to leave the camper fully supplied the whole time, and the fridge cold. If I have to shut it off, it'll take hours and hours to cool it back down when I return.
    Thanks for any input!
  2. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    reallistically, yes.
  3. Wrenchgear
    3,459
    718
    Aug 5, 2010
    5 Star Eagle Camper
    Hmmm.... Normally if you were camping with it, all would be good. We've camped for 3 weeks in one spot with the fridge on propane, and never gave it a second thought. I don't want to get your OCD or superstitions or nerves going, but if it was me, I would be thinking about it the whole time I was gone, and that thing was there by itself running on propane. The campground might also have a problem with it going like that if they knew it was unattended, (but they'll never know). I'm not sure what I would do.
  4. Jimbow
    Jimbow Well-Known Member
    1,521
    126
    Nov 30, 2012
    I turn mine on at my storage unit and come back in two days. I never gave it a second thought.
  5. generok
    generok Well-Known Member
    2,782
    1,073
    Feb 7, 2013
    Anchorage, AK
    I've left mine on LP in storage mode for days on end. Never worried about it in the slightest.
  6. jmkay1
    5,637
    2,453
    I'm not sure what I would do in that instance either. I've seen propane accidents and had kids play with my propane tanks when I was away from camp. Thank goodness I had an attentive camp neighbor who shoo'd them away. Apparently they loosened the lines and caused me to have a slow leak.
    It's one thing for it to be just overnight, but not sure how I feel about it for so long. I'm probably just paranoid though.
    Spridle likes this.
  7. Spridle
    Spridle Well-Known Member
    1,180
    379
    Jun 6, 2011
    Some of us are less paranoid than others. I wish I was one of those that was not paranoid.
    zak99b5 likes this.
  8. PopUpSteve
    PopUpSteve Administrator
    19,443
    2,087
    Dec 22, 2002
    Malvern, PA
    All the safety concerns aside, if the flame goes out (not even going into how and the gas leak that would ensue), everything in the fridge would go bad and you wouldn't know until you get back. So my suggestion is to take with you what you need for the first part of your stay, take home what remains, and bring back what you need for the second part of your stay.
  9. xxxapache
    3,273
    1,247
    I'd go home with it running with no worries.
  10. SteveP
    SteveP Well-Known Member
    1,726
    528
    We often leave the campsite on day trips for the entire day and we leave the fridge, and wh, running while we're gone. If you're concerned about someone messing with your propane tanks get a hard cover and put a lock on the access cover or replace the ACME nut connection with an old style POL. If propane flow does get interrupted the safety interlocks in the fridge valve will prevent propane flow once the flame dies. If the fridge is not safe to run while you're away it's not safe to run while you're sleeping.
    As the other Steve says, I wouldn't recommend leaving anything in the fridge that could spoil before your return, but drinks, water, etc. would be ok.
    Strawhouse and zak99b5 like this.
  11. davido
    davido Active Member
    936
    232
    Jul 17, 2014
    A well maintained propane fridge is safe.
    A neighbor down the street from me had their 3-way fridge catch fire and burned the RV to the ground. It was a spectacular, unfortunate event. The fire was caused by the fridge's ELECTRICAL system, not by its propane system.
    A PUP fridge will go for about 3 weeks on a full 20# tank, give or take a little depending on the fridge size and design. They're really efficient. Leaving it running while you're gone for a couple days is probably fine. It wouldn't worry me. But do make sure it is well maintained and in good condition. No rusted out parts, no gas leaks or old cracked propane hoses, that sort of thing. And make sure the vents are not obstructed.
  12. zak99b5
    178
    108
    Feb 21, 2019
    Thanks for all the great responses. I wasn’t going to leave meat and such in it while we were gone, more like condiments and beverages, maybe half and half for my coffee.
    I know it’s not a pilot light in the true sense, but the flame is basically the same as a pilot light. And won’t the thermocouple **** off the propane if the flame goes out?
    I lit the fridge today as a test. Flame looked perfect (though I did ignite some propane in the chimney because it didn’t light right away).
    If it’s running solidly for a few days before I leave camp, I think I will let it continue to run. If anything seems even minutely out of whack, I’ll shut it down and bring some blue ice blocks to help it cool down more quickly when I return.
  13. tarawes8182
    tarawes8182 New Member
    18
    May 17, 2018
    Scottsdale, Arizona
    We live in AZ and go by the rule that if there is a flame, it needs to be watched. With that said, I'm also a person that never tows my PUP with the LP on either (plenty of debate on that as well). I'm always said of something catching fire and burning.
    Plus, my OCD would not allow me to keep it on. I know I wouldn't be able to stop thinking about it, but at the same time I have never had an issue with my fridge. We have installed some fans to help move the hot air out but that was only to increase efficiency not due to a real issue.
    I agree with others. If it's maintained, has no leaks, and you feel comfortable leaving on then it should be fine.
    Kyle R Thorson likes this.
  14. zak99b5
    178
    108
    Feb 21, 2019
    Update: we're back home, and the camper is still at the site. Fridge was running fine, but I caught a whiff of propane at the tank connection (happened once last year as well). Shut it down and reconnected the tank, then fired up the fridge again. I checked it every so often, and it seemed fine, but it still made me a bit paranoid (trying hard to smell gas, it's hard not to think you don't smell it lol). That, coupled with the fact we are leaving it for two nights, made it easy to decide to shut it off.
    Going to replace the pigtail connector when I get back, though. I thought about grabbing a new one and bringing it back to the camper, but I'm not sure of the length or the size of the connector that goes to the regulator. I'm guessing it's only a foot long and 3/8" male, but with my luck it won't be.
  15. Duneready
    Duneready New Member
    Aug 26, 2018
    Lansing, Michigan
    Does your frig need 12v power?
    Will your battery last long enough?
    Just wondering
  16. zak99b5
    178
    108
    Feb 21, 2019
    No. It's just the standard small Dometic 3-way.
  17. Clemens
    Clemens New Member
    Nov 2, 2019
    I think it is pretty safe. I would be more concerned if I left the water turned on.
  18. CampingFamily1
    CampingFamily1 Active Member
    874
    240
    May 12, 2007
    Minneapolis/St. Paul, MN
    We have to monitor the temp in our refrigerator. On very hot days it needs help by adding ice. If you're not there to add ice, things go spoil.
    I wouldn't leave it burning unattended that long myself.
  19. dbbyleo
    dbbyleo Member
    202
    Jun 27, 2013
    There shouldnt be any problem with leaving your camper at a campground with the fridge running on LP.
    The main concern with running fridge on LP Is when you’re traveling ... and that’s because of the pilot light / flame. If you were to pull into a gas station, that could set off gas fumes ... would be like lighting a cigarette at the gas station... you just don’t do it. So I would say the same thing to some who leave it running in storage units. You never know what the guy next to your camper is doing with his camper... if he is handling gasoline for some reason next to your camper or something.
    But a campground... shouldn’t be an issue.
