Safe to use furnace
Discussion in 'General Camper Setup / Take Down' started by steve313, Mar 22, 2020.
  1. steve313
    steve313 New Member
    Mar 22, 2020
    hi there new to pop up trailers. We just purchased a 2003 coleman sante fe. we want to work on it while self isolating but its around 0c(32f). i was curios if the furnace can be turned on while down to warm the canvas up before opening it. or is there a safety switch?
  2. WrkrBee
    WrkrBee Well-Known Member
    2,842
    1,134
    Welcome to the Portal from South Carolina. If you have power available, put a small electric heater, on low, in it for awhile.
    WVhillbilly likes this.
  3. Raycfe
    15,815
    1,817
    Many furnaces are connected to the safety switch with the dome lights, etc.
  4. steve313
    steve313 New Member
    Mar 22, 2020
    our little heater isn't working lol. is 0c to cold to open it. just don't want to wreck anything
  5. WrkrBee
    2,842
    1,134
  6. steve313
    steve313 New Member
    Mar 22, 2020
    thanks
  7. kcsa75
    kcsa75 Well-Known Member
    3,183
    1,518
    Sep 9, 2013
    Kansas City
    Congratulations on the NTU Pup and Welcome to the forum from Midway USA.
    Unless somebody removed it, there is a safety switch either on the main body or on the roof to cut off electricity while it's closed. You can probably circumvent that by raising the roof a few inches or a foot, which shouldn't hurt the canvas any.
    Also, make sure you have some propane if you're going to fire up the furnace.
  8. bobinfleet
    bobinfleet Active Member
    521
    215
    Sep 2, 2011
    Hampshire UK
    I would pop the trailer up and extend the bunks but not put the bunk tension rods up ( is that what you call them)? then put the heater on to warm up then put the rods up
    Tronicus likes this.
  9. Sjm9911
    5,235
    2,841
    32 is cold, not to rain on your party, but i would just wait untill it warms up a bit. Working in the cold ,is well, cold.
    kcsa75 and bheff like this.
