sanitize in-line water filter?
Discussion in 'Plumbing Systems (Blue, Grey, & Black)' started by John the Baptist, Jun 9, 2021 at 6:38 PM.
  1. John the Baptist
    John the Baptist Member
    49
    Aug 22, 2017
    Hi,
    We've been out about 8 times now and have never worried about sanitizing the in-line water filter I add to the campground water supply but wondering if I should.
    I drain it for days sitting on end (outlet down) in the sun when I get home, but a little air pressure into it always gets a few more drops out.
    If it needs it, how would I do it?
    Thanks!
  2. Sjm9911
    9,315
    6,714
    I never have. Dont blow out either. Its just a charcoal filter. And it drys out. Its not like mold will build up in it. But who knows.
    xxxapache likes this.
  3. Raycfe
    17,422
    2,984
    Never have either. I do cap the ends when in storage. I just start the new season with a new one.
    xxxapache and Sjm9911 like this.
  4. jeepster04
    jeepster04 Active Member
    172
    100
    Nov 23, 2010
    I would just replace it at least yearly, if not twice a year, and not worry about it.
    All a charcoal filter does is help with taste and filter out some sediment.
  5. John the Baptist
    49
    Aug 22, 2017
    Thanks all!
    The current filter has only 15 days or so of use on it, so I think I'll go another trip or two and replace. I've never smelled or tasted any badness or gotten sick after it sits for months, so I will continue ignoring it.
    I appreciate your time.
  6. tzmartin
    tzmartin Not here for a long time but here for a good time! Diamond Supporting Member
    1,338
    667
    Sep 9, 2015
    Clayton, Georgia
    The filters can go longer than you think. The ones I use say they have microban pellets or something like that to reduce mold etc. I store it on end in the popup so it can drain out inbetween trips.
  7. WrkrBee
    5,691
    2,911
    I use a whole house filter with the housing that unscrews. I drain the filter at the campsite, bring it home, remove the filter, and dry everything (hose, housing, filter, regulator, Y-s, caps, and plugs) on top of the fridge in the garage. Reassemble before the next trip.
  8. John the Baptist
    49
    Aug 22, 2017
    You've all been helpful. I appreciate it.
