scary ride
Discussion in 'On The Road' started by animlvr, Jul 31, 2017.
  1. animlvr
    animlvr New Member
    Jul 31, 2017
    brantford, ontario
    first time out with our Fleetwood, the trailer didn't seat right on the hitch, thank goodness we had just pulled off our main highway 403 and decided to go home the quieter less traveled highway 5, the trailer popped off our hitch - and slid to a stop under the back of our truck, the propane tank guard stopped it from taking off the valve, other than break the battery tie down strap and some bent chain, we were very very lucky - our first trip out could have been our last. we are now extra vigilante and double check everything before leaving the campsite, again at the gate, and once more on solid road. please be safe out there.
    we couldn't thank the good samaritans enough who stopped to help us get the trailer back on the hitch, I had called CAA and they were en route to us, but since the trailer's back end was still in a live lane, we needed help asap, 3 ladies (myself included) sat on the back bumper of the trailer while the men hooked it back up...i was shaking in my boots - the rest of the way home we crawled, both of us keeping one eye in the mirror, the other on the road. I never want to experience that again, we have since purchased a newer ball, and installed locking pins, and better chains.
  2. JPBar
    JPBar Well-Known Member
    1,873
    584
    Sep 22, 2016
    Texas
    Glad to hear no one was hurt.
    MistyL and animlvr like this.
  3. Haybale
    2,523
    374
    Aug 22, 2013
    San Diego via MN
    I learn some things the hard way also!!
    Thanks for the post as it will help others be safer and hopefully bring awareness!!
    MistyL likes this.
  4. Fischymom
    Fischymom Active Member
    146
    49
    Jul 28, 2017
    Always a great reminder, thankfully no one was injured or killed.
  5. f5moab
    1,421
    470
    May 7, 2013
    Somewhere in Idaho
    Never had it happen, but I still use one of these to prevent the trailer from popping off the ball. It cannot go any higher than the bottom of the plate.
    It uses the same bracket as the coupler connect that helps a single person back up and get the hitch on the ball....
    JustMePatrick, myride and RWilk like this.
  6. ezakoske
    ezakoske Active Member Gold Supporting Member
    593
    109
    Nov 30, 2014
    Escondido, CA
    That looks like a handy device to have - Do you recall what it is called? I have the guide to help back onto the ball for my boat trailer which I had forgotten all about - it's on the shelf in my garage somewhere....
  7. f5moab
    1,421
    470
    May 7, 2013
    Somewhere in Idaho
  8. chambo
    chambo Active Member
    358
    114
    Apr 27, 2015
    Southern California
    Glad everything worked out. Thanks for sharing.
  9. tfischer
    tfischer A bad day camping beats a good day at the office Gold Supporting Member
    4,180
    1,657
    May 21, 2014
    Glad it worked out OK.
    You should be able to feel with a finger to make sure the latch is below the ball. To be completely safe, hitch it up, then raise the jack until you're sure the vehicle is raising with the tongue (this will be a few inches as the first bit will just be the springs relaxing).
    Also make sure you're using the correct size ball. A 1 7/8 ball on a 2" adapter is not safe.
    CheekyRunner likes this.
  10. generok
    2,923
    1,303
    Feb 7, 2013
    Anchorage, AK
    Yikes! Glad you were okay! The lesson learned the hard way lasts a lifetime.
  11. xxxapache
    3,469
    1,472
    I had a boat trailer I had owned 20 years come off the ball at interstate speeds when I hit a seam in the road. The couple was secured with a lock. The metal jaw inside the couple must have flexed when I hit the seam. It is nothing more than stamped sheet metal. A near 3k lb trailer riding on the chains at 65 mph in heavy traffic is exciting. I got the rig stopped with no damage...I bought a repair kit and replaced the guts in the coupler.
  12. kskelloggs
    kskelloggs New Member
    29
    Sep 16, 2016
    Wonderful Wyoming
    Glad everything worked out for you! I've had 2 different trailers come off when towing them, one a flatbed loaded with cement blocks at internet speed, and the 2nd a 2 horse trailer loaded with 2 horses. Neither time was fun and hope nobody else has to experience something like it. But, people around here pull all kinds of trailers ALOT so the chances of something happening are probably a bit better than in some places. Still, be safe people and have fun!
  13. crackerJack
    crackerJack Well-Known Member
    1,182
    360
    Jan 6, 2014
    Scottsville, KY
    We double check it this way.
  14. davido
    davido Well-Known Member
    969
    270
    Jul 17, 2014
    I'm curious how it was possible to latch the coupler latch without fully engaging the coupler.
    In other words, if you drop the coupler onto the ball, and it doesn't go all the way down, it would be next to impossible to fully close the coupler's latch to the point you're able to slide a pin or padlock shackle through its security hole.
    I wonder if possibly your hitch ball is the wrong size.
    shuang2 likes this.
  15. Fbird
    Fbird Active Member
    262
    116
    Sep 10, 2017
    Ferndale MI
    always double check. mine came off on a nasty dirt road. mine had a old coupler with a built in lock. the lock hadn't worked in a long time and no parts available. the latch finally failed and the trailer came off. got it rehitched and drove 300 miles home with duct tape holding the latch. so double check its hooked up properly and everything works.
  16. Scottcampers
    Scottcampers New Member
    Jan 27, 2018
    I tow my pup with my kids any chance I get. The last trip my husband decided to go with us and I was glad he did this time. The tred came off one of the trailer tires going through the mountains. We saw the tred behind us but didn’t realize it was ours. We made it safe to our destination an hour after it happened. But we had to make a stop due to another problem, the door of the trailer unlatched and was swinging open. My husband isn’t a camper and this trip didn’t warm him up to it either.
  17. myride
    myride Well-Known Member
    1,114
    572
    May 14, 2015
    Edmonton, AB
    First words out his mouth were....."and you like camping why?"
    jmkay1 and Scottcampers like this.
  18. Raycfe
    17,007
    2,595
    I was waiting for my wife in a parking lot and down the line was a pickup with a popup hitched up. Mining my own business I just sat in the car. I watch a gentleman walk by the popup and stop and stare at the hitch, then walk on to his car. Something told me something wasn't right. So I took my dog for a walk and made sure we also walked by the popup. The coupler latch wasn't down ........ and the guy I watched just walked away, some people just don't care about others. I knocked the pickup's window and I think woke up the driver taking a nap. Told him about the couple latch, which he thanked me for, he had just driven 200 miles that way! SEE something, SAY something ..... I guess is a good thing. I sure would want someone to tell me about a problem, low tire, etc.
    Haybale likes this.
  19. nineoaks2004
    8,244
    3,700
    Dukes, Fl
    Lucky that you didn't have a worse time and that no one was hurt. It pays to take time to double check things, problems occur when we get in a hurry and skip the double check..
    MY boat came off the ball once, when we hooked up the night before it started raining so each of us thought the other had checked the hitch and no one did, I made it 2 blocks down the road and the boat passed me on the street, all it did was go over to the ditch and take a mailbox out, The hitch lock was not locked down, now I use a padlock EVERY time I hitch anything up. Good Luck and Happy Camping. Luckily the mail box belonged to my fishing partner.
  20. Natureangel
    1,118
    326
    Feb 28, 2016
    Illinois
    I keep mine padlocked as well.
