Sceaming converter?
Discussion in 'Introduce Yourself' started by Mert0109, Jun 16, 2018.
  1. Mert0109
    Mert0109 New Member
    Jun 16, 2018
    hello. I just purchase an 2007 Starcraft RT 14’ When I turn on any power item or such as lights or fan the converter screams. Or is it the converter? Any ideas or help?
  2. nineoaks2004
    8,244
    3,700
    Dukes, Fl
    sounds like the fan either has bearings going or has a wasp nest or something causing it to be out of balance. You might try some lubricate on it, if it quietens then the bearings are probably going.
  3. Raycfe
    17,007
    2,595
    I second the fan causing the noise. I would try to get some oil on its bearing.
    6ad4135f4a202c41426d6f8c1f8a6abc--welcome-to-group.jpg from the Connecticut shoreline.
  4. tombiasi
    6,092
    1,624
    Did you try it just on battery without AC?
  5. DJS12354
    DJS12354 Well-Known Member
    1,580
    502
    Sep 21, 2017
    Greetings from NEPA! Hope you get your issue sorted out quickly.
  6. Mert0109
    Mert0109 New Member
    Jun 16, 2018
    Yes. Does the same thing.
  7. joet
    5,010
    1,076
    The only moving part in the convertor is the fan. Like others has asked/said you need to get some oil to the fan bearings
  8. tombiasi
    6,092
    1,624
    The noise doesn't have to be from a moving part. There are electronic components that can oscillate. Does the fan run with no AC?
    Canadian Campers likes this.
  9. Canadian Campers
    Canadian Campers New Member
    22
    May 22, 2018
    Caledonia, Ontario, Canada
    My converter screamed out and then popped and never worked again :(
