Scissor jacks unscrewing
Discussion in 'General Camper Setup / Take Down' started by JimmyM, Jun 26, 2017.
  1. JimmyM
    JimmyM Well-Known Member
    2,382
    566
    Jun 5, 2014
    Franklin, MA
    I was setting up last weekend and the front scissor jacks won't stay in place. The front is lower than the back, so the jacks aren't deployed terribly far. Maybe 12-14 inches. I crack them down to stabilize, and as soon as I take off my drill, the screw spins backwards and the camper comes down. Mind you, I'm not trying to lift the whole corner, just bring the stabilizer down and put some weight on it.
    I didn't think these screw jacks were supposed to be able to do that.
    Any similar experiences?
  2. kitphantom
    11,805
    885
    The stabilizer should be snug, but not lifting at all. The description of spinning backwards and camper coming down sounds like you are actually lifting the camper a bit.
    We have never had ours "unscrew". We have had to re-tighten them under some soft surface conditions on a few occasions.
  3. Antipodes
    Antipodes Call me Paul
    772
    75
    Jan 28, 2015
    Christchurch, New Zealand
    No they should not unscrew like that! Not sure if you have lubed the threads at all but they may do this if very well lubed.
    I only use a Teflon spray and leave to dry, don't want to attract dust and grit which in most cases caused more friction.
    The scissor jack is used quite often for wheel changing on cars, so it does not do this when it has a load on it or we would all be injured from changing tyres.
    Don't have a solution for you, but someone else may!
  4. JimmyM
    2,382
    566
    Jun 5, 2014
    Franklin, MA
    The screw turns a couple of times very quickly. The camper only drops an inch or 2 maybe. To put weight on them the weight has to come from somewhere. That's the weight on the wheels/suspension. So ANY force on the stabilizers will lift the camper to some degree.
    But the whole idea behind a screw jack is that it can't unscrew itself. I did lubricate them but jeez! Also it looks like the "nut" end has a thrust bearing there too.
    I'll have to "un-lube" them?
  5. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    rub some dirt on it, it'll be ok...lol..[CC]
    crackerJack and JimmyM like this.
  6. Antipodes
    772
    75
    Jan 28, 2015
    Hahahaha, yeah that will screw them, so to speak.:D
    JimmyM likes this.
  7. Haybale
    2,483
    307
    Aug 22, 2013
    San Diego via MN
    I would unlube them....
    I have used scissor jacks as stabilizers for years without issues. I just spray them lightly with a dry silicone spray.
  8. smit1088
    smit1088 Well-Known Member
    1,582
    78
    Mar 15, 2011
    Stillwater, MN
    Do they unscrew when you use a standard handle on them instead of the drill?
  9. VTRailroadguy
    VTRailroadguy Active Member
    216
    60
    Aug 19, 2015
    Northwestern Vermont
    Clean off the grease and try it again. Friction keeps them in place, so I bet you just got things too slick.
  10. kitphantom
    11,805
    885
    Re-reading, I realize we have the non-scissor style. However, any style jacks should hold with weight on them, scissor jacks use for vehicle tires definitely need to not lower. I know some have said they've gone to a junkyard and bought those to use for the pups.
  11. Haybale
    2,483
    307
    Aug 22, 2013
    San Diego via MN
    That's what I use!!
    RollTideRick likes this.
  12. RollTideRick
    RollTideRick Member
    45
    May 31, 2017
    Getting ready to install 4 GM Jack's on the Forrest River. The fold down stabilizers are too much work.
  13. f5moab
    1,423
    468
    May 7, 2013
    Somewhere in Idaho
    Deleted
  14. nineoaks2004
    7,381
    3,140
    Dukes, Fl
    I bought two jacks from HF for about 35.00 each and installed them in the front of my TT, the rear came with jacks. I have never had screw jacks "unscrew" actually they are not made to level the unit, the front is leveled using the front tongue jack, then the stabilizers go dow to sturdy the unit.
  15. JimmyM
    2,382
    566
    Jun 5, 2014
    Franklin, MA
    Yup. I level side to side with linx blocks and front to back with the tongue jack. But when I screw down the jacks to put some weight on them, they unscrew a couple of turns after I take the drill/handle off.
    The camper only "lifts" an inch or so to put weight on them.
    I'll be "un-lubing" them when I de-winterize. Just a spritz of dry lube.
  16. tombiasi
    5,363
    1,000
    Are you sure they are unscrewing and not just taking back play in the lift assembly? By design I can't envision how they can unscrew.
  17. JimmyM
    2,382
    566
    Jun 5, 2014
    Franklin, MA
    Oh, no. They're definitely unscrewing. I don't get it either. Screw jacks aren't supposed to be able to do that. But here we are.
  18. JimmyM
    2,382
    566
    Jun 5, 2014
    Franklin, MA
    Getting the existing grease off is gonna be a pain in the a**. I used lithium grease stick.
  19. tombiasi
    5,363
    1,000
    I really don't think grease is your problem. Jacks can't unscrew. The force on the screw cannot move the screw.
  20. JimmyM
    2,382
    566
    Jun 5, 2014
    Franklin, MA
    Dude. I know what I'm seeing. I didn't think it was possible either. a single pitch screw shouldn't be able to back out.
