Scissor jacks unscrewing
Discussion in 'General Camper Setup / Take Down' started by JimmyM, Jun 26, 2017.
  1. tombiasi
    5,954
    1,498
    I didn't mean for you to get your shorts in a bunch it's just a claim like that has to have questions asked.
  2. JimmyM
    JimmyM Well-Known Member
    2,893
    901
    Jun 5, 2014
    Franklin, MA
    Agreed. I think it stems from the "nut end" having a roller thrust bearing.
    I got a quick video of it. It's definitely backing out. Slower this time.
  3. tombiasi
    5,954
    1,498
    Damn! I have never seen that in my life. The thread shouldn't allow this. Did someone replace the threaded shaft?
  4. JimmyM
    2,893
    901
    Jun 5, 2014
    Franklin, MA
    I know! Right? Completely agree with you. Sooo messed up. They're factory screw jacks. Only lubed by me. That's it. Last year, it would spin back quicker, but still...
    I know it only happens when the ground and camper are close together due to the angle of the arms vs. screw. But it shouldn't do it in ANY case. There's a relationship between the pitch angle of the screw and coefficient of drag between the nut and screw. But I find it hard to believe that the screw/nut interface is THAT friction free.
    But there's no doubt it's happening.
    If anyone is interested in what lube I used... Lith-ease grease stick.
    https://www.amazon.com/gp/product/B000Q6JUB8/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
  5. giadiep
    giadiep Active Member
    430
    192
    Sep 5, 2015
    Syracuse, NY
    Just hit it with a can of brake cleaner, then see if it holds. Brake cleaner should remove the grease.
  6. JimmyM
    2,893
    901
    Jun 5, 2014
    Franklin, MA
    That's what I was hoping.
  7. tombiasi
    5,954
    1,498
    If you determine that the lube was causing this I'm buying some of that immediately.
  8. mstrbill
    mstrbill Active Member
    692
    146
    Mar 17, 2013
    Austin , Texas
    I thought Silicone spray was the lube of choice for the stabilizers. Prevents dirt from building up on the screws.
  9. crackerJack
    crackerJack Well-Known Member
    1,178
    354
    Jan 6, 2014
    Scottsville, KY
    Crazy......idk
  10. Haybale
    2,509
    338
    Aug 22, 2013
    San Diego via MN
    To much lube on the screw...
    Brake cleaner should be fine to clear it. Or simply put a little bend in the screw...
  11. JimmyM
    2,893
    901
    Jun 5, 2014
    Franklin, MA
    I don't think I'm emotionally or psychologically capable of bending the screw to stop it from unscrewing. [:P]
    jnc likes this.
  12. ezakoske
    ezakoske Active Member
    587
    100
    Nov 30, 2014
    Escondido, CA
    I'd just replace them if degreasing them doesn't do the trick.
  13. FarmerDave
    FarmerDave Active Member
    653
    46
    Jun 15, 2012
    Nova Scotia
    Had the exact same thing happen with a TT. You could see the screw winding backwards with weight on it. Wasn't my trailer so I don't know how it got solved.
  14. Rusty2192
    Rusty2192 Well-Known Member
    1,016
    448
    Jul 30, 2014
    Kentucky
    JimmyM likes this.
  15. Joeman55
    Joeman55 New Member
    Aug 16, 2018
    Matthews, NC
  16. Joeman55
    Joeman55 New Member
    Aug 16, 2018
    Matthews, NC
    I'm trying to get all that white lithum off my rear Jayco screw jacks. They both spin back down once I take the jack handle off.
  17. RollTideRick
    RollTideRick Member
    45
    May 31, 2017
  18. WrkrBee
    WrkrBee Well-Known Member
    3,921
    1,703
    A screw is nothing more than a wedge wrapped around a rod. The pitch of the screw is the same as the angle of the wedge. If you reduce the friction on the top and bottom of the wedge and the downward force generates enough force to create the needed 90 degree force, from the angle of the wedge, the wedge will move (or the screw will turn).
  19. RollTideRick
    RollTideRick Member
    45
    May 31, 2017
    Dedicated my life to building hotrods and working in the Collision Repair Industry, I have possibly used every jack invented. I think Air Bags would be awesome on my Pup but the wife said "Enough of all of the gadgets"
    WrkrBee that's what I was going to say!
  20. Sjm9911
    6,969
    4,361
    To be honest , I'm pretty mechanical , and have no clue as to what that means.
