Screws to attach vent to aluminum roof?
Discussion in 'Roof/Floor Repair & Maintenance' started by Benjamin Lee, Oct 3, 2021.
  1. Benjamin Lee
    Benjamin Lee New Member
    Sep 15, 2021
    Hello everyone. I am trying to finish up our roof rebuild and am trying to get some insight of the best screw type to attach the air vent to the roof? I have seen where stainless can create issues when attaching to the aluminum roof. What should I go with? A pic for reference. 2000 fleetwood Sedona.
  2. Sjm9911
    10,618
    8,000
    Is the vent aluminum or plastic?
    Benjamin Lee likes this.
  3. xxxapache
    4,089
    2,369
    My whole trailer is aluminum. My vents and much of the hardware came from the factory attached with stainless screws.
  4. Benjamin Lee
    Sep 15, 2021
    It’s aluminum with plastic cover. Pic below. Vent line brand.
  5. Sjm9911
    10,618
    8,000
    They have aluminum screws, but i think most places would use zinc plated, that look like stainless but aren't. I looked up vent line on amazon, it says galvanized flange. Tbh, dont think it matters much. Drill a hole , and the screw bites into the wood and really dosen't touch the aluminum to do much. Set it in the brutal tape, caulk and be done with it. Dissimilar metal stuff happens, but i dought it will effect much in your application. If it was like galvinized and copper sweted pipe, i would be worried. But it isnt.
  6. Benjamin Lee
    Sep 15, 2021
    Awesome. Thanks for the insight. I just went ahead and got stainless sheet metal screws. I’ll roll with it that way and just seal up well
  7. xxxapache
    4,089
    2,369
    Put sealant on the screw threads before you put then in., then on the heads when done.
    Raycfe and Benjamin Lee like this.
  8. Benjamin Lee
    Sep 15, 2021
    Wrap butyl tape on threads?
  9. xxxapache
    4,089
    2,369
    No...use RV caulk.
  10. pm3579
    pm3579 Indiana U.S.A.
    102
    Dec 28, 2008
    Indiana
    No don't punch holes in a perfectly good roof. 30 years in roofing I can tell you where it will leak first. Sooner or later all penetration's will leak.
  11. Sjm9911
    10,618
    8,000
    I have to ask, how would you suggest he holds the vent to the roof then? I have yet to see a roof vent without holes for fasteners? Even in roofing, you need to screw or nail down a vent? Caulk and tar only goes so far.
    xxxapache likes this.
