Seam between plywood on pull out bunk needs reinforcement-how?
Discussion in 'Miscellaneous Repairs & Maintenance' started by Thomas McComas, Jul 21, 2020.
  1. Thomas McComas
    Thomas McComas New Member
    Jul 20, 2020
    Minneapolis
    How should I reinforce this seam on king size pull out bed on 2000 Jayco Eagle series 10 UD pup? There was luan or paneling stapled to top and bottom and it was not doing the job. The seem gets caught when I pull the slide out the camper. There is not much room for for wood below the pullout, and that is why the factory used 1/8 luan I think. I removed the luan that was "holding" the two pieces of plywood together. The 1/2 plywood itself is in great shape, just bowed a bit and am thinking: 1/4 plywood, luan, sheet metal, straight steel brackets, or whatever has worked for you! to cover the seem on both sides -- inside and outside of the camper.
  2. Thomas McComas
    Jul 20, 2020
    Minneapolis
    I chose what I think will be a permanent fix: bought 2 pieces of hardened 1045 steel 1/8" x 4"x76" and connector nuts and bolts. Drilled holes through the steel and sandwiched the plywood between.
    __________________
  3. TRR
    TRR Active Member
    455
    224
    Nov 3, 2014
    Alabama USA
