Search tab in front of login...
Discussion in 'Hey PUP Staff, Let me tell you what I think!' started by SHFL, Dec 1, 2020.
Thread Status:
Not open for further replies.
  1. SHFL
    SHFL Active Member
    504
    166
    Jan 6, 2015
    Florida
    The search tab is in front of the login in button — so I only login in when there is a picture that I want to see. (I can't find any other way to login.)
    Does anyone else have this problem?
    How do you work around it?
    Thanks in advance!
  2. kitphantom
    13,218
    2,324
    on my ipad, the search tab appears in front of my "Alerts" lines. I can get the alerts, though. I figured it was something weird with the iPad version. Haven't looked at it on the phone recently, I mostly use the laptop (windows with Firefox)
    ETA (12/2) I looked at my iPhone and the search tab is not an issue there either, just on my iPad.
  3. eoleson1
    eoleson1 Well-Known Member
    3,613
    1,732
    Jul 5, 2011
    Macomb County Michigan
    Sometimes using a different browser can change the layout. How are you trying to log in? What kind of device? Which browser?
  4. PopUpSteve
    PopUpSteve Administrator
    20,010
    2,930
    Dec 22, 2002
    Malvern, PA
    You totally lost me on that part of your comment.
    So but I have no control on the way XenForo (the forum software developers) handles the display of the menus for different devices.
    It would be helpful (I will email them your question) to know what type of device you are using along with what OS version. Thanks
    kitphantom likes this.
  5. Toedtoes
    Toedtoes Well-Known Member
    2,846
    2,821
    May 28, 2018
    Oftentimes, the browser "scrunches" the website to fit the screen. Sometimes it is as simple as turning the device horizontal to expand the page.
  6. SHFL
    SHFL Active Member
    504
    166
    Jan 6, 2015
    Florida
    Since I can’t see the login button, the only way I can get a login screen, is to click on something that requires that I be logged in to see it. Then a screen comes up and informs me that I must login.
    I am using Safari, on an iPad mini.
    I will try another device – – and see if I still have the problem.
  7. Toedtoes
    2,846
    2,821
    May 28, 2018
    Have you turned the ipad mini horizontally?
  8. SHFL
    SHFL Active Member
    504
    166
    Jan 6, 2015
    Florida
    I’ve tried it portrait, and landscape. In both cases, I cannot see the login button.
    However, I just discovered the “you must log in to reply” link, so I can make this work…
    Thanks!
  9. eoleson1
    3,613
    1,732
    Jul 5, 2011
    Try installing the Firefox browser on your ipad. I use it on my phone with zero issues.
  10. PopUpSteve
    20,010
    2,930
    Dec 22, 2002
    Malvern, PA
    There should be a little checkbox when you logon that is an option to "Stay Logged In". Click that and you shouldn't have any more issues with logging on until the next ti you clear the cache.
    McSkippy and kitphantom like this.
  11. Tom Jordan
    Tom Jordan Active Member
    183
    147
    Jun 3, 2019
    ArkLaTex
    I have the same issue on my iPad mini with Safari. It started a number of months ago, then was corrected, then started again. It’s a pain since it covers the alerts as well as the New Posts. Steve’s “Stay logged in” option has worked well enough.
  12. Arruba
    Arruba Well-Known Member Gold Supporting Member
    690
    359
    Nov 28, 2014
    Central Oregon
    I’m on an IPad, the Search covers up everything right of my Avatar. I can see the LIKE button light up behind the Search Bar. Does no matter what the orientation of the screen is.
    Using iPadOS 14.1 maybe .2. It’s been this way for a little while. Don’t know what it looks like on a phone or PC.
  13. PopUpSteve
    20,010
    2,930
    Dec 22, 2002
    Malvern, PA
    And don’t forget, they update these browsers all the time and there are also so many ways to personalize them too. I see the issue you are having when I use my iPhone to view the website with chrome but not with Safari. The combinations are endless.
  14. SHFL
    SHFL Active Member
    504
    166
    Jan 6, 2015
    Florida
    Thank you for the suggestions. When I get some time I will try a different browser.
    I might even stay logged in...
  15. Katskamper
    Katskamper Well-Known Member
    864
    283
    Nov 21, 2015
    Fort Worth, TX
    Admin Steve:
    the coders have not coded for mobile devices!
    im on ipad mini. using safari.
    search is blocking because its html tag or CSS that needs adjusting. i will look when im in front of my computer & can view source code. ( I'm assuming its a float right tag.)
    can you edit the HTML or CSS.?
    search needs to be in its own <div> above the navigation bar or immediately after the membership nav link.
    will detail answer tomorrow.
  16. SHFL
    SHFL Active Member
    504
    166
    Jan 6, 2015
    Florida
    I love the breadth of knowledge that portal members have!
  17. PopUpSteve
    20,010
    2,930
    Dec 22, 2002
    Malvern, PA
    I've passed it along to the software creator but don't hold your breath.
  18. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    I have the same problem on my iPad.
  19. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    BTW - the problem went away briefly (for a few weeks), then came back. This was a few months ago.
  20. PopUpSteve
    20,010
    2,930
    Dec 22, 2002
    Malvern, PA
    Most likely browser updates caused it to not work, then work, and then not work again.
    Bottom line, nothing I can do. Sorry.
    You may want to try a different browser on your device.
Thread Status:
