Seeking velcro help!
Discussion in 'First Time & New Camper Owners' started by Crc310, Apr 23, 2019.
  1. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    What can we do about this. The Velcro is shot next to the door. When the wind blows, this part opens and if raining, will let rain in. Duct tape? Lol It was a free camper. Didn’t want to spend a lot of money. I have no idea how to replace the Velcro. Thoughts?
  2. J Starsky
    J Starsky Well-Known Member
    745
    527
    Aug 3, 2017
    East Central MN
  3. Eric Webber
    Eric Webber Active Member
    202
    128
    Jul 7, 2018
    Montreal, Quebec, Canada
    You can buy heavy duty external velcro (sticky back) for dirt cheap
    Crc310 likes this.
  4. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    Would I remove the existing Velcro? Also, I cant fully stretch it over the Velcro on the door. I can get about halfway.
  5. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
  6. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    Snaps won’t work as I can’t fully stretch the Velcro over...
  7. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    Here’s a few more pics. The Velcro doesn’t align...
  8. kitphantom
    11,721
    833
    Which part of the Velcro seems worn out? The hook side can get clogged with lint, etc. I have a little wire brush to clean Velcro,but have had it so long I don't even know where I got it. (It's like a tiny wire pet brush)
    If part of the problem is that the canvas doesn't reach all the way, what order are you doing things in, when do you try to connect it? On our second pup, we had to attach the Velcro to the door before putting the shepard's poles in the bunk ends, or it was too taut to reach. Also, if the canvas is too tight, the shepard's poles may need an adjustment.
  9. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    We r the 3rd or 4th owner. I think we have been opening it then velcroing. Not sure. We left it opened in our garage all winter. The Velcro is clean but bad, doesn’t catch...
  10. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    Close up
  11. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    Closer
  12. BikeNFish
    BikeNFish Well-Known Member
    2,852
    1,759
    Apr 24, 2017
    Maplewood, MN
    You could try this:
    But don't light your pup on fire!!
    Crc310 and Sjm9911 like this.
  13. J Starsky
    745
    527
    Aug 3, 2017
    East Central MN
    Think you need to loosen the alum strip holding the canvas and slide it over? Is it loose at the zipper side, like too much material toward the bunkside and short on the door side?
    Or, could you make a 4in strip with velcro on both sides to bridge the gap? Like a belt from a thrift store which you'd put Velcro on? Spitballing...
  14. Sjm9911
    4,449
    2,273
    It does look as if the tenting is not right. I would try to slide it over also.
    Crc310 and J Starsky like this.
  15. J Starsky
    745
    527
    Aug 3, 2017
    East Central MN
    You can sew with a sewing Ahl. I didn't think I could either, but turns out, after practicing on some old jeans, that I can. Harbor Freight has a cheap sewing Ahl that works good enough.
    Crc310 likes this.
  16. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    Can’t hand sew, my fingers are too painful for that... I can’t even see patches on my sons scouts shirts... will look into a sewing awl though. Thanks!
    J Starsky likes this.
  17. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    May have to practice on something first so I don’t set the camper on fire Thanks!
  18. Crc310
    Crc310 New Member
    21
    Sep 17, 2018
    Michigan
    Thank you! Will see if we can shift it.
    Sjm9911 and J Starsky like this.
  19. J Starsky
    745
    527
    Aug 3, 2017
    East Central MN
    You really might have to loosen the alum rails that hold the fabric in place, but I bet you can pull it back where it belongs. Good luck!!!
  20. Zephyr
    Zephyr Active Member
    287
    53
    Jun 18, 2013
    central Oregon
    This is good to know, but I probably would catch something on fire and make the problem worse. I wonder if a heat gun (like a hair dryer on steroids) would be effective and safer?
    Crc310 likes this.
