Selecting new tires for viking saga St175/80D-13
Discussion in 'Tires / Brakes / Bearings / Axles' started by vdotmatrix, Jun 29, 2020 at 12:22 PM.
  1. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    st175/80D13
    Is what is on there now.
    it is far time to have these replaced.
    when i search for these tires i usually get the C rated 1360lb tires instead of the D rated.
    oh, and i should get radials over plys right?
    what i found was tire rack had the c rated tires and then i bring them over to NTB to have them installed for about $15.
    I could buy them from pepboys or premounted from amazon.
    any ideas. Thanks
  2. WrkrBee
    WrkrBee Well-Known Member
    3,551
    1,510
  3. Sjm9911
    6,410
    3,777
    How heavy is your camper? The c and d load eange is for weight? I like radials for highway driving, some still like the bais. So thats up to you. Next you need to look at the speed rating. Most are higher now, so you would want those.
    vdotmatrix likes this.
  4. MNTCamper
    MNTCamper Well-Known Member
    1,091
    326
    Jun 14, 2014
    MN
    I ordered Carlisle D load online in that size, not an issue. Installed locally.
  5. Brian K
    Brian K New Member
    Jun 28, 2020
    Sjm9911 and vdotmatrix like this.
  6. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    Thank you...I was trying to find these locally and just went to PEPBOYS. What a mistake. They quoted me a really cheap price but the quote had no tire size and when I looked it up online it was just a mess without any specific detail. I like the easy pre-rimmed tire, pre-balanced all I have to do is just put them on, but then I will have the old wheels to deal with--environmentally responsible? But I am torn and leaning toward the easy way out.
  7. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    The tire dept. at PEPBOYS said you don't want to put radials on a trailer ( popup)?
  8. Sjm9911
    6,410
    3,777
    Go to a real tire place, lol. And dont bring anything back to pep boys. Most people go with the radials now, especially for highway driving, less heat, better tracking, etc. This equals less blow outs. Some like there basis tires, there older technology, and there better for dirt roads, rocks etc. But you can get whatever you want. Just make sure all 3 tires match. You dont want to run a bais and a radial at the same time.
    vdotmatrix and kcsa75 like this.
  9. Dstinnett875
    Dstinnett875 New Member
    May 25, 2020
    Huntsville AL
    My "new" camper has the same size tires that are 4 yrs old and im thinking I might need to replace them also. I'll be following to see what it's suggested.
  10. Adam H
    Adam H Active Member
    483
    184
    Aug 22, 2015
    Try the 185/80/13, more selection and only slightly larger. I got mine on Amazon 4 years ago and will do so again after this year.
  11. kcsa75
    kcsa75 Well-Known Member
    3,641
    1,843
    Sep 9, 2013
    Kansas City
    If you have Discount Tire in your area, I can't recommend them highly enough. They will price match anybody and the customer service is excellent.
    IF you opt for tire and wheel combo from an online reseller, I would still take them somewhere and have them balanced. Balancing for most tire/wheel combos means they put the heavy side of the tire 180 degrees from the heavy side of the wheel and call it good.
  12. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    I still dont know what I will do the the old wheels....Wondering if I should just get the tires and have them mounted and balanced on the existing wheels....NTB doesnt carry the D load rated tires. https://trailersetgo.com/store/rainier-st175-80r13-lrc-radial-on-13-5-lug-white-spoke-assembly
    PRODUCT NAME
    Rainier ST175/80R13 LRD 8-Ply Radial Trailer Tire
    PRICE
    $63.00
    QUANTITY
    TOTAL
    $189.00
    Remove
    PRODUCT NAME
    Rainier ST175/80R13 LRD Radial on 13" 5-Lug White Spoke Assembly
    Center Cap: None
    Lug Nuts: None
    Tire Balance: Y
    PRICE
    $91.50
    QUANTITY
    TOTAL
    $274.50
    Remove
  13. WrkrBee
    3,551
    1,510
    Can NTB order the D load rated tires? If not, and that's what you want, it's online time.
  14. Snow
    10,667
    1,407
    I use my old ones as winter storage tires, swap them around the same time I swap the vehicle tires..
    Dstinnett875 likes this.
  15. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    They dont come in the d rated tire from them.
  16. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    One last thought, i should probably buy 3 tires so i can have a spare.
    I am going to call ntb and tire rack to see if they will mount tires that i dont buy from them.
  17. zak99b5
    zak99b5 Active Member
    137
    72
    Feb 21, 2019
    Are you getting the D load rating from the "80D13" in the size? If so, that D means its a bias ply tire, not the load rating. You don't say what pop up you are towing, and many are light enough for C load-range tires (2700# capacity with two tires)
  18. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    I am just replacing the tires that are on there now ST175/80r-13
    Now you make me re-think this about the D rating..... heading to the storage area now.....
  19. vdotmatrix
    vdotmatrix Member
    301
    Feb 11, 2013
    I have loadstar tires on there right now...
    Sorry it is in my profile 2001. Viking saga g2107
    A731EE7E-3E64-4FEF-8384-740D712709C9.jpeg 47E72951-0DCB-4198-8591-A50F1DFBFB58.jpeg 60F7266C-4504-4AA9-90B5-9720B871958B.jpeg 30F07739-FDAD-489A-8698-9DF0B5144B77.jpeg 18AB5696-7C6F-4FDE-91F3-796C27B3863F.jpeg
  20. zak99b5
    137
    72
    Feb 21, 2019
    Link no workee.
