Seven pin connection
Discussion in 'First Time & New Camper Owners' started by The Baroness, Oct 16, 2021.
  1. The Baroness
    The Baroness New Member
    23
    May 27, 2018
    Well it seems every time I go out I break something new on the camper. I guess it’s learning the hard way (?)
    so I pulled my car ahead while the 7 pin was full attached and this came unattached. It looks like something that *should* reattach fairly easily but I can’t for the life of me figure out where. Any ideas?
    thanks!!!
  2. SteveP
    2,257
    931
    I'd look for it inside the drivers side rail of the tongue, possibly under the battery or propane mount.
  3. Grandpa Don
    Grandpa Don Well-Known Member
    1,417
    1,065
    Sep 5, 2018
    Southern California
    It doesn't look damaged, so you can just plug it back in. My camper has the same type connection. It's on the right side of the tongue.
  4. The Baroness
    23
    May 27, 2018
    Got it! Had to take apart a panel under the tongue and then just plugged it right back in. Thanks!
    Grandpa Don, SteveP and Snow like this.
  5. davido
    davido Well-Known Member
    1,217
    542
    Jul 17, 2014
    Once you get it plugged in, check the connection including brakes. Verify all signals / running lights / brake lights / electric brakes work. There's a possibility you could have damaged the wiring inside that cable.
