Severe weather
Discussion in 'General Weather Forum' started by KamperKel, Dec 28, 2018.
  1. KamperKel
    KamperKel Active Member
    149
    77
    Nov 5, 2017
    I need some advice. We are currently going through a severe thunder storm. My question is is it better to unzip the windows to allow the wind to pass through or should we zip up? We are in a Rockwood HW277.
  2. jmkay1
    4,904
    1,785
    I personally just zip up everything. I take the awning down in heavy wind. Never had a problem. It's just going to be scary for awhile. A couple times I moved my car to buffer the wind some. The only time I had to close everything up was when a low grade hurricane hit.
    kitphantom and KamperKel like this.
  3. KamperKel
    149
    77
    Nov 5, 2017
    Thank you!! It was getting a little scary.
  4. nineoaks2004
    7,382
    3,141
    Dukes, Fl
    Leave it zipped then hunker down until it is over. Good Luck
    KamperKel likes this.
  5. KamperKel
    149
    77
    Nov 5, 2017
    Thank you, that is what we did
  6. tombiasi
    5,367
    1,001
    Would you actually open all the windows and let the rain blast in?
  7. jmkay1
    4,904
    1,785
    . Speaking for myself, when I found my roof shaking like crazy in the wind it got so scary I also considered opening a couple windows to help. After all that's what they tell you to do during tornados, at least they did way back when. I'd rather deal with rain then a broken lift. Ultimately I decided to weather it myself and just hoped manufacturers knew what they were doing. If it's your first time in a popup during a bad storm you begin to question everything.
  8. tombiasi
    5,367
    1,001
    I think if it was that bad I would lower the roof rather than flood the inside of the pup.
    durhamcamper likes this.
  9. Sjm9911
    4,686
    2,440
    How severe is the weather? I think in tornadoes they said to do it because the pressure would blow out the windows. I dont know if that holds true for the newer type. I had my pup up in 50 mph winds buttoned up tight, i wasnt in it but it held up with no ill effects.
  10. Sjm9911
    4,686
    2,440
    Just had to add, if its huricane weather, micro bursts or tornados , i would pack up the pup and seek shelter. If just a thunderstorm i wouldent worry too much. With wind events be weary of parking the pup under dead branches etc.
    neighbormike likes this.
  11. neighbormike
    2,347
    1,744
    Oct 6, 2012
    WI
    Hope you all survived the storm intact!
