1. spearmint
    spearmint New Member
    293
    Aug 5, 2007
    Does anyone know the exact sizes of double, queen and king-size regular bed sheets? I want to see if I can match them up with my pup bed sizes to buy sheets. The bunks are 48x77 and 66x77.
  2. sd102
    sd102 New Member
    423
    Nov 7, 2007
    I know regular mattress sizes, maybe this will help...
    full - 54 w x 75 d
    queen - 60 w x 80 d
    king - 76 w x 80 d
    cal. king - 72 w x 84 d
    Sue
    2001 Coleman Utah
  3. sewserious
    sewserious New Member
    509
    Jun 4, 2007
    Sizes on popups are not the same as regular beds (see chart below). The best thing I have found, if you can't sew, is to buy jersey (t-shirt) sheets a size smaller. They have enough stretch to fit well and no worries. If you can sew a straight stitch, taking the closest regular but larger size fitted sheets, removing the elastic, opening up the corners, and resewing corners and elastic is the ULTIMATE solution. Use the next smallest flat sheet on top. You can also take the next smallest size flat sheet, cut the correct size corners, sew, and add elastic.
    Twin Mattress Size 39" w x 75" l
    Twin Extra Long Mattress Size 39" w x 80" l
    Full Mattress Size 54" w x 75" l
    Full Extra Long Mattress 54" w x 80" l
    Queen Mattress Size 60" w x 80" l
    Queen Split Mattress 60" w x 80" l or Two 30" x 80"
    King Mattress Size 76" w x 80" l
    California/Western King Mattress 72" w x 84" l
    Me '60 DH '56 DD#1 '82 DD#2 '90
    DGD#1 '01 and DGD#2 '04
    '01 Oldsmobile Silhouette <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle>
    '93 Coleman Roanoke <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle>
  4. themanfromvan
    themanfromvan Van, PA - Near The PA Wilds
    2,109
    53
    Jul 31, 2004
    Van, Pennsylvania
    We have always just take larger flat sheets and tucked them under.
    A word to the wise - don't use flannel sheets in your PUP. The are like humidity sponges and feel very damp until your body heat dries 'em out.
    David, Betsy, Elizabeth, Olivia & Robert
    '01 Rockwood Freedom <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp">
    Nights Booked In 2008 - 10
    www.themanfromvan.com
  5. spearmint
    293
    Aug 5, 2007
    So glad you mentioned that as I was going to take flannel sheets for early camping days! Now I know better.
  6. sewserious
    509
    Jun 4, 2007
    I am just the opposite, I love flannel sheets for camping; especially when it is 20 degrees outside at night! I use a pretty thick mattress pad on our bed and then flannel sheets on that. The humidity around here is only about 20 to 40 percent in the winter, really dry, so maybe that is why we don't have that problem.
  7. jthomas124169
    jthomas124169 Member
    718
    Jul 13, 2005
    Frederic Michigan
    I just use regular sheets and tuck the extra under the mattress.
    Julie(58) DD(81) 2 DGS(98)&(02) DF(42)
    "Its only a flesh wound" Monty python and the holy grail
  8. spearmint
    293
    Aug 5, 2007
    I think I will be using regular sheets, too. The price of pup sheets is way too much. I am just wondering whether the king-size fitted sheet or the king-size flat sheet is best for covering the mattress in the 66x77 bunk bed. Perhaps the flat sheet is best because the good amount of tuck will help the sheet stay on and will be very easy to remove.
  9. CmpFmly5
    CmpFmly5 New Member
    52
    Apr 16, 2008
    use regular sheets and get some sheet stays at walmart.
    If all else fails, get a new else.
    Wife for 7 years, Together for 17 years.
    Aiden to be 6.
    Cole 3.
    Jack 1.
    Westie named Pipsqueak Pepperoni.
