Shocking find.
Discussion in 'Tow Vehicles, Hitch & Towing' started by xxxapache, Sep 1, 2021.
  1. xxxapache
    4,089
    2,375
    One of my trucks has been riding rough for a while. Not hard to diagnose when you crawl under the truck and find rust holes in the shock absorbers. One was completely broken in two. All that held it together was the rubber boot. They were 11 years old with about 80k miles. Those shocks started out life white. I believe the rubber boots probably accelerated the rust....That didnt stop me from putting some bright colored ones on for some bling on the new shocks.
  2. Sjm9911
    10,645
    8,034
    That could have been much worse. You dogged a bullet there.
  3. ccarley
    ccarley Active Member
    156
    30
    Sep 23, 2014
    Wow, I've seen some bad shocks but those were amazing!
  4. Tarkus
    Tarkus Member
    81
    59
    Aug 15, 2021
    Wyoming
    Acid rain?
  5. xxxapache
    4,089
    2,375
    Road salt. The boots kept the shocks from ever getting washed off.
    MNTCamper likes this.
  6. silvermickey2002
    4,905
    714
    Sep 11, 2008
    Morris County, NJ
    Ok, that is one nasty shock!!! I'm sure road salt had a little to do with it, but the stuff they use now (Brine) is worse.
  7. xxxapache
    4,089
    2,375
    Brine is liquified road salt....lol.
    True it is bad for your vehicle, especially if you get in it right after its sprayed and hasn't dried. Where I live they spray it at even the mention of snow. When it actually does snow, they spread rock salt like it's free.
    I treat my truck annually with Fluid Film. That shock would have faired better without the boot and getting sprayed with Fluid Film or me pulling the boot down and spraying the shock and putting the boot back on. Either way, they were worn out. They were over 10 years old and had 80k miles.
  8. ccarley
    156
    30
    Sep 23, 2014
    I bet those new KYBs ride pretty nice... well especially after having no damping!
    xxxapache likes this.
  9. xxxapache
    4,089
    2,375
    Yeah, the truck certainly rides better.
    I put KYB Gas-A-Justs on one of my other trucks a few years ago. They gave a nice ride to it. I figured they would work pretty well on this one.
    The old shocks were Pro Comp ES3000. I think the truck rides a little softer with the KYBs than it did when the Pro Comps were new.
  10. Tarkus
    Tarkus Member
    81
    59
    Aug 15, 2021
    Wyoming
    Road salt is why I don't bother to put snow tires on my vehicles each winter. Though snow tires work better, I just slow way down and get same results without maintaining two sets of wheels.
    Because of all the salt, we have as many car washers as gas stations. More for the under-surface cleaning to slow down the salt corrosion.
  11. generok
    3,323
    2,108
    Feb 7, 2013
    Anchorage, AK
    So, this post took me down a rabbit hole this morning... I know my OEM shocks are pretty much ok with only 50K on them and we don't salt our roads up here. But it got me thinking perhaps an upgraded rear shock could help smooth out my towing ride some. I spent some time on KYB's site, then went to Amazon and local dealers (Amazon always cheaper, but usually out of stock, which is the case with these shocks for my truck). Then I got to thinking about upgrading the equalizer on the TH to smooth out the ride, which led to hunting down heavy duty shackle and wet bolt kits, and a look at a new set of SAE and metric impact wrench sockets. So, all in all, that's $735... oh wait, going to need another floor jack to get the weight off the TH axles... that's $250... So up to $985 now. I'll just round up to a cool $1K.
    Fun morning, thanks! Glad you got on this. I remember thinking my old Explorer was riding rough. Pulled the rear struts to find the springs in 5-6 pieces. Well, that was fun! I also vowed then and there: I will NEVER rebuild struts at home. I will just get complete kits and swap out. (I elected to rebuild the fronts... big mistake and huge time sink).
  12. 1380ken
    1380ken Well-Known Member
    2,762
    1,176
    Nov 7, 2013
    Mass
    The underside of my car looks like the Titanic
    Tarkus likes this.
  13. RonDad
    RonDad Active Member
    115
    117
    Aug 11, 2020
    North Carolina
    Let us not forgot the springs.
