Shortest Camping Trip Ever?
Discussion in 'Let me tell you about my trip' started by jorgewolfe, Oct 16, 2017.
  1. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    So rushed home from work Saturday night about 6 pm and hooked up the PUP to go for a 2 night stay at a nearby campground. Recently bought a 1978 Starmaster 6 and put new wheels on and several other upgrades. Everything checked out (including torque on 9 out of 10 lug bolts) #10 would stay somewhat snug but nowhere near the recommended torque - all others seemed pretty good. Well, as we turned to leave our neighborhood at about 7 pm we heard a loud crash behind us. Long story short #10 bolt bailed on us after about 2 blocks and his 4 co-conspirators jumped out about 100 feet later. We dragged that hub and sideways wheel for about 1/2 mile before there was a place to safely pull over. Managed to jack up the PUP and remount the wheel well enough to drive home. Big project ahead!
    J Starsky likes this.
  2. xxxapache
    3,143
    1,134
    It's hard to believe 4 out of 5 properly torqued lug bolts would fail that quickly....But something similar happened to me. I had a wheel fly off a trailer at about 45 mph when the wheel hadn't been off in years. I found either 3 or 4 out of 5 lug bolts all within a short distance of each other.
  3. megcabra
    megcabra Well-Known Member
    2,209
    564
    Aug 12, 2015
    Chapel Hill, North Carolina
    Wow, that stinks! Hope you can get it fixed and get out another weekend to the campground.
  4. xvz12
    xvz12 Well-Known Member
    854
    487
    Apr 6, 2017
    New Plymouth, ID
    I had a similar issue with a boat trailer years ago, I had just bought the thing, checked the lugs before our first trip. but at about the 50 mile mark, the tire & we parted ways....turned out that wheel was the right lug pattern, but the center hole was just ever so slightly too small, preventing the wheel from snugging up against the hub. A frantic trip around the Council area netted us five lug nuts, & some washers to use as spacers, which got us home.
  5. davekkk
    davekkk Active Member
    452
    44
    Oct 7, 2013
    Wisconsin
    That's kind of freaky!
  6. J Starsky
    J Starsky Well-Known Member
    790
    583
    Aug 3, 2017
    East Central MN
    I had an 6 lug chevy front wheel leave a suburban once - wasn't that it was loose, that 3 lugs snapped, then the all did after a corner. Freaky as heck for sure!
    JiffyPopJunkie likes this.
  7. thethird152
    thethird152 Active Member
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    I put new tires on my pup about 2 years ago, torqued everything down, and hit the road for a rally. Made it about 30 mins down the road and noticed the street side wheel was a little wobbly. Pulled off the highway and into a gas station to check it out, and all 5 lug nuts were gone - somehow the wheel was magically still on the camper, though the wobbling had bored out the lug nut holes enough that I couldn't put new ones on. The lug nuts themselves were somewhere out on I-40. Pulled the spare off the back and used the 3 lug nuts on it to limp slowly to an auto parts store (there was luckily one very close by) and bought new lug nuts. Drove the rest of the way to the rally without issue, but with constant visions of me sending a 15" camper wheel into oncoming traffic at highway speeds - I still get the willies thinking about it. I've put about 2k miles on the camper since then and have not had a single issue with the wheels. It makes me want to get one of those little gremlin bells for under the camper :)
    Glad to hear you came out unscathed, and hopefully without too much damage to your camper! Good luck with the fix!
  8. MsMac
    MsMac Well-Known Member
    589
    256
    May 19, 2016
    We had a lug issue on our way out of town several weeks back. "User error", as they say. Someone (not me :) ) forgot to tighten the bolts on one wheel after working on the brakes. We made it about a mile down the road before we heard a thudding. I pulled over immediately and my partner took a look at the rig, thinking we had a flat. Nothing. So, we started again. Not 100 yards later, he said, "pull over now, I know what it is". Sure enough, 4 of the 5 bolts on our curb side were missing. He was able to poach 2 of the lugs from the other wheel to get us back home, while I walked the road to try to find the bolts. I found one, which after looking at it, needed replacement anyway. We went to town to try to find replacements. No luck at the auto parts store or the tire store. Tractor Supply had them, fortunately.
    Our lesson learned from this is to make sure that one project is completely finished before another is started. We were so frenetic getting prepped for the trip that he simply got sidetracked doing something else before putting the wheel back on properly.
    If it had to happen, it was truly the best possible outcome. I shudder when I think of what could have happened had that wheel actually come off. :(
  9. mpking
    mpking Well-Known Member
    1,367
    362
    Jun 17, 2014
    Raynham, MA
    I think I had a slightly shorter trip.
    I boogied on home from work. Typically I don't work Fridays, but I got called in on an all hands meeting. I pull up at 3pm. We open up the camper, load up, and close it back down in 30 minutes. I backup to the hitch, and ....... the jack failed. I couldn't move it up, nor down. No movement means I can't get it on the ball of the car (never mind get it off and level at the campsite). The trip ended right there. I valiantly tried to find a replacement jack, but due to the original having an odd outer dimension size (1 7/8") I couldn't find one locally on Friday. Found one at 11am Saturday, but by then we had already canceled.
  10. nineoaks2004
    7,848
    3,467
    Dukes, Fl
    Scary, However it failed fairly close to home (for what that is worth) and of course it could have been much worse especially if you were doing really high speeds. Sounds like someone had over torqued the lugs, This happens when using air wrench to install wheels, this stretches the lugs and make them weak. Glad no one was hurt. Good luck with the repairs and Happy Camping
    Bowman3d likes this.
  11. 4xMeteor
    4xMeteor Active Member
    621
    75
    Jul 30, 2012
    Georgia
    That stinks and is a bit scary - good to hear no one was hurt. Haven't had any issues with trailers, but had the rear wheel of my VW fly off once doing about 50mph in town. Earlier that day had the VW at the shop for brake work, so the shop ended up paying for the tow bill. On another trip with some friends, we were all in their Blazer, the rear wheel flew off at 70mph in the middle of the NV desert. Both times no one was hurt and we managed to find the tire and get going again.
  12. tombiasi
    5,819
    1,400
    Maybe you should recheck the specified torque for your camper.
  13. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    Alr
    Reckon I will as soon as I get new hubs on there (with STUDS!!!)
  14. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    Thanks for the good words. Yes they were super tight. I reckon I'll switch to studs on new hubs!
  15. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    Wow! very similar only we were only doing 30mph! Glad you also made it!
  16. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    Thanks :smiley:
  17. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    Wow! Great story (the ending anyway!)
  18. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
  19. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    You got me on the duration!
  20. jorgewolfe
    jorgewolfe Member
    38
    Aug 22, 2017
    Sparks Nevada
    Good outcome - we are still shuddering a little!
