Should I be concerned?
Aircamperace
May 23, 2014
43
Should I be concerned about running my heater with the couch bed folded out?Obviously I would want the area under the bed clear, maybe even use a fan? You can see the furnace grill under the couch in the pic with the couch folded up.
3hooligans
629
Boston
My U shaped dinette has the furnace under it as well, But not as far back as yours. I had the same thought. But I haven't need to use the U shape as a bed yet. I think if it built that close to the floor it should be ok that close to the bed, Just make sure nothing drapes in front of it. feel the under side of the bed after it has been running for a while and see.
RockyRoo
Just because you CAN doesn't mean you SHOULD
Jun 8, 2012
6,626
I wouldn't think they would build something that would be a fire hazard, however I do question the efficiency. I would put a fan at that opening under the bed and pull the hot air out and as was said, make sure nothing drapes down in front of it.
efehser
4,614
Not a fire hazard, but you definitely want a fan under there, or the only warm person gonna be the one in that bed.
