Should I get LT or P rated tires
Discussion in 'Tow Vehicles, Hitch & Towing' started by TravelingAggie, Feb 5, 2021.
  1. TravelingAggie
    TravelingAggie Member
    80
    32
    Sep 22, 2019
    South Central PA
    Hi All!
    I just recently upgraded my TV to a 2018 F150 XLT SuperCrew with the 157" Wheel Base
    3.5 L Turbo V6
    3.55 Rear
    275/65/R18
    10,700 max towing
    7,050 GVWR
    Mostly drive highway miles. Rarely go offroad.
    Im towing a 2015 Jayco 1007UD that has a GVWR of 2,550lbs
    Heres my question.
    On my last truck, my tire guy recommended i get LT rated tires. Seemed a bit overkill to me for a pop up but he said that just in case i ever switch to the dark side and get a conventional camper. The tires im looking at have a load limit of 2756lbs per tire for P rated (11,024lbs for 4 tires) and the LT are 3,415 lbs per tire of load rating (13,660lbs). Seems like the LT tires are a bit over kill for my truck since the load limit of 4 P rated tires is over my trucks GVWR but i wanted to get an opinion here.
  2. Anthony Hitchings
    3,168
    1,883
    Mar 2, 2019
    Oakland, California
    either way - look for tires with low road noise
  3. Sjm9911
    10,783
    8,165
    Your probably good with the pup. I wouldn't worry about it Unless you go bigger and have problems. Hes was trying to sell you new tires. I went bigger and had some sidewall roll in the p tires. Its not exactly the weight they can carry but the stiffness of the tire sides ( how many plys they are). Some flex a bit with more weight and towing feels squirmy in the rear of the truck. But, for a pup your fine. Dont buy stuff if its not needed.
    kcsa75 likes this.
  4. generok
    3,358
    2,150
    Feb 7, 2013
    Anchorage, AK
    Well, you certainly don't need LT tires. If you wanted to get into an A/T tire, you might need to go LT to get what you want. I have the 2014 version of the same truck, and I do run LT A/T tires on mine, but I use a high percentage of my tow capacity and spend hundreds of miles on gravel. P tires are less expensive, ride nicer, and are lighter.
    neighbormike likes this.
  5. xxxapache
    4,119
    2,430
    You can also go somewhere in the middle with XL (extra load) rated P metrics. I have them on a half ton and tow a 6500 lb TT with it with no complaints.
    kcsa75 likes this.
  6. Overland
    Overland Well-Known Member
    481
    390
    May 1, 2013
    Bristol, Pa
    I'm also in Pa.. SE. My tire guy would not mount LT tires on my wheels when i mentioned installing them on a trailer.. said it's illegal in Pa. I knew nothing about it, but these guys are good people and a family run business since the 60's so i trusted his knowledge.
    That being said.. i went elsewhere and didnt mention what i was putting them on..
    Mayhem Galore and kcsa75 like this.
  7. Snow
    11,816
    2,393
    LT tires will give you stiffer sidewalls and less wallowing when you get the truck loaded up.. Put LT BFG KO2s on my 1500 and love them...
    Seeing how LT tires are infact stiffer then ST tires, I would double check what your tire shop said.. if I could find LT tires in 14 size I'd put them on my TT..
  8. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    TravelingAggie is replacing tires on the tow vehicle, not the camper.
    Overland likes this.
  9. xxxapache
    4,119
    2,430
    I would like to see a link to a PA law that says its illegal to put LT tires on a trailer.
  10. SteveP
    2,285
    948
    Depends on the roads you're traveling. If driving on paved roads the P types will be quieter, smoother and provide better gas mileage. If driving off pavement the LTs have tougher sidewalls and are less susceptible to road hazard damage. As long as the load range of the tire is sufficient for the load you're carrying I wouldn't worry about that.
    xxxapache likes this.
  11. Dingit
    Dingit Well-Known Member
    1,813
    1,276
    Mar 8, 2017
    My truck rides really rough. I'm not holding the LT tires entirely responsible but they can't possibly be helping.
  12. Sjm9911
    10,783
    8,165
    They definitely stiffen up the ride. When not towing or hauling i usally air them down a tad. Otherwise you will feel every bump.
    xxxapache and generok like this.
  13. xxxapache
    4,119
    2,430
    I have ran LT tires on my compact pickup for over 20 years. It doesnt weigh but about 4k pounds. Max sidewall pressure on the tires is 50 psi. I only run 32-35 lbs. I have no complaints on ride compared to the P metrics that came stock on the truck.
  14. firepit
    firepit Well-Known Member
    2,547
    4,009
    Feb 26, 2020
    I run mastercraft courser AXT2 on mine...the call them all terrain but to me they are more of a hybrid/tweener.
    My BFG's were way more aggressive and noisy.
    These are pretty darn quiet as well.
    They are reasonably priced and held up well
  15. xxxapache
    4,119
    2,430
    I ran 3 sets of BFG ATs on my small pickup and 2 sets on my Jeep. I did not find them noisy. What I appreciated about them was the 3 peak mountain/snowflake rating which many AT tires do not have.
  16. TravelingAggie
    80
    32
    Sep 22, 2019
    South Central PA
  17. brettstoner
    brettstoner Active Member
    100
    107
    Jun 17, 2014
    Toledo, OH
    Common misconception. LT tires are not needed. The passenger tires Ford specified are rated to handle the GVWR; i.e. the maximum amount of weight the vehicle could weigh fully loaded. So even if you are towing a trailer and have loaded your pickup to capacity, the passenger tires would be rated to carry the load. Pick a tire that meets your criteria for longevity, budget, road conditions, and noise/vibration/harshness. I personally prefer P rated for the softer, quieter ride.
    Also I know of no federal or state law that prohibits LT tires on a trailer. Any replacement tire must be rated to carry the weight but there is no law against putting different types of tires on a trailer. So I will weigh each tire on the vehicle using individual scales, measure each tire PSI, then look at the load rating stamped on the sidewall. If the tire is not at the maximum inflation pressure then I look up the tire in a load inflation table to determine if the tire at that psi is rated to carry the weight. I will typically only do this after a fatal crash and there are indications tires played a factor in the crash or I am doing a routine inspection and tires appear subpar/non-standard. Then I will measure each PSI and verify the tires are rated to handle the load.
    RonDad likes this.
  18. RonDad
    RonDad Active Member
    115
    118
    Aug 11, 2020
    North Carolina
    I think part of this decision is how frequently you tow. Should be able to get P rated that handle the max capacity of an F150 (given that you’d have to add a weight distributing hitch at the right time). If you’re only towing a small percentage of the time, P rated are widely accepted to give a better/quieter highway ride.
    Adjusting PSI to the load conditions is also good advice. I tow the pop up with the same pressure as normal driving. But would increase/decrease with heavy cargo - of if/when we ever go to the dark side.
  19. SlinginIron
    SlinginIron Active Member
    122
    37
    Apr 21, 2016
    Dayton, WA
    It depends on where you go. You stated mostly highway and very little off road. If you are taking gravel roads in the mountains I would steer clear of a passenger vehicle tire. They are often 4 ply, and I've had to utilize the spare way too often with those to recommend them (rock punctures only no sidewall damage). If it was me, I'd go LT load range E (10 ply). Someone previously mentioned bfg at tires, I think they are great, I've also run the general tire ATX. The generals were great as well. Michelin makes more of a highway tire that reduces road noise and consistently lasts 70000 miles. As far as road noise and a rougher ride, I really have to disagree with some of the posts. Tire technology has come a long way and the noise from an all terrain now isn't much more than a highway tire. The ride is the big difference. I have 10 ply ATs on both my F-150 as well as my wife's explorer and the ride is much better on those than it was on bfg ATs previous version just a few years back. Very comparable ride to a passenger tire! You get what you pay for with tires as with other things. Good luck!
    kcsa75 likes this.
  20. Dingit
    1,813
    1,276
    Mar 8, 2017
    Does anyone air down their tires for a more comfy ride while towing? (Towing a popup--not something heavy...)
