newbiecamper
After putting down the Camplite after the rains finally gave up for a couple days, i see i am in the market for new sideboards. i know there is topic after topic on the subject, and i have read most of them. But its too much to try and put it all together, so im gonna ask anyway.
1- is there a standard as to the thickness of the material used to make the new sideboards? I am referring to the wood in itself, not including the trim-coil or whichever material is used.
2- How exactly are the sideboards attached to the end boards and roof? i have seen the
L-brackets on mine in the corners. Is this the norm across the board to the roof as well? Or does it simply screw into the wood framing around the roof?
3- My roof has a very generous curve front and back, and my question is what is involved in making/replicating that curve, in the event i have to do a complete roof rebuild?
I am more concerned with the sideboards, as these hold the lift arms and the latches for the roof. the end boards are not the best, but as long as it sheds water im ok with them.
TIA as usuaL for all the comments, advice, info and help. if i have not said said it befor I will now, THIS SITE IS AWESOME!!!
