Side rails
Discussion in 'Mystery Parts' started by Franchesca, Nov 4, 2020.
  1. Franchesca
    Franchesca Active Member
    106
    43
    Nov 2, 2020
    Massachusetts
    Where can I get 2 of these side rails for my 2000 Thor Skamper Vision M-25GL? They are 48 1/2” x 1 1/2”.
  2. PopUpSteve
    PopUpSteve Administrator
    20,118
    3,099
    Dec 22, 2002
    Southeastern PA
    You say side rails but I can't picture where these would go. You have additional photos, perhaps with the ones you have installed?
    Franchesca likes this.
  3. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    Bed supports?
  4. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    When you raise the top of your camper these bars might be safety bars that prevent the top from crashing down if the cable breaks. They fit over the bars that raise the camper.
    tombiasi likes this.
  5. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    No they cover the 4 post that raise the camper when you crank it up.
  6. WrkrBee
    6,569
    3,461
    Many make them out of PVC pipe.
  7. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    I don’t think we are speaking of the same thing. I’ve seen pvc used in securing the bump out beds but not for covering the square lifts that raise and lower the roof.
  8. Sjm9911
    10,775
    8,150
    They dont have to cover the lifts , just keep the roof up. The roof dosen't care if the side lift peices are covered or not! [:D]
  9. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    I thought they were necessary to hold up the roof if it started to fall.
  10. Sjm9911
    10,775
    8,150
    Yes, but they dont have to go around the posts. They have to just go into the space between the roof and the boady. Just put them next to the posts. Or cut a channel in a peice of pvc. Or get a 2x4. Or a peice of pipe.
  11. Sjm9911
    10,775
    8,150
  12. SteveP
    2,283
    948
    You only need 2. Put them in alternate corners, 0ne front, the other back, opposite side.
  13. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    Thank you for the info. This website is really great for information. I’m learning a lot about pop ups.
  14. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    That’s exactly what I was doing! Thank you for confirming I was doing it correctly. Do the pop ups only come with 2??
  15. BigAl
    BigAl Active Member
    141
    117
    May 22, 2019
    Wisconsin
    Yes, only two are included. If you need to replace you can use 2x4 or PVC pipe as mentioned above, or you can buy metal replacements here (they call them safety posts on the diagram): https://goshenstamping.com/lift-system
  16. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    Thank you
  17. 2000skamperSPORTm17A
    2000skamperSPORTm17A New Member
    23
    Sep 20, 2016
    These ARE definitely the 'safety' support bars that slip over 2 of the 4 lift posts after fully extended. Skampers only shipped with TWO; place them in opposite/diagonal corners. Do you have none...or were you thinking you needed 4?
  18. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    When I only saw 2. I thought the other 2 were lost. I previously thought you needed 4 to be safe.
  19. Sjm9911
    10,775
    8,150
    No, you only get 2! Lol. Problem solved and no work. Have fun!
