Sink removed
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by jimg57, Jul 26, 2017.
  1. jimg57
    jimg57 New Member
    May 24, 2016
    [​IMG] [​IMG] I removed the sink and water holding tank from my popup, we never used the sink, so
    this allowed me to remove the holding tank and use that floor space to better use
    The sink and holding tank are stored in my attic, in case I sell this camper
    Jhoag7750 and Tracy D. like this.
  2. davekkk
    davekkk Active Member
    452
    44
    Oct 7, 2013
    Wisconsin
    Do you have a pic at all?
    I did a similar thing, stored it up on a bracket way up high in my garage in case I ever need it. Never thought I would use the space since its behind the wheels but it fits 4 life jackets and other light items perfectly. Have you figured out a good outdoor sink? I am still trying to figure that out.
  3. camscrub17
    camscrub17 New Member
    Aug 22, 2016
    I'd like to see pics as well; I've got to remove mine as well - We don't use the sink or stove and that flip down garbage cabinets got to go!
  4. TammyHerra
    TammyHerra New Member
    Sep 6, 2018
    Everywhere
    Most of ours is gone. That flip counter was in a few pieces... We removed the top- used a shelf that was same size to put a plastic dish pan inset on top of lower portion of that scrappy cabinetry. The drain and small water holding tank still there... We have not removed them yet because we weren't sure if we wanted to... The more I think about it the more I can see gained space to revamp as we need like actual usable storage?? Thanks for the thoughts.
  5. Jesse Ramos
    Jesse Ramos New Member
    17
    Aug 21, 2018
    Racine, WI
    im currently remodeling my camper and took the sink and stove counter out and replaced it with a new flat counter. i plan on adding marble vinyl on top to spruce it up. counter top.jpg 65103426_2273871082861499_7807907243097063424_n.jpg
    HappyTraveler and Ntk37 like this.
  6. MNTCamper
    MNTCamper Well-Known Member
    1,268
    451
    Jun 14, 2014
    MN
    My sink is removed also, gives us much more counter space. I've left the fresh water tank in under the camper since that is tucked out of the way.
  7. Jesse Ramos
    17
    Aug 21, 2018
    Racine, WI
  8. Ntk37
    Ntk37 Member
    37
    26
    Jun 7, 2019
    How did you remove the stove? I want to do this too, but don’t know how to safely do that with gas lines and such.
  9. Raycfe
    17,175
    2,780
    Find the Tee connection under the camper and disconnect the line for the stove and cap it. You will need a ⅜ flare cap.
