Slamming door
Discussion in 'Miscellaneous Repairs & Maintenance' started by yarzy, Jun 8, 2015.
  1. yarzy
    yarzy Member
    88
    Jan 25, 2013
    Hi everyone, is there anything I can install on my Fleetwood that would prevent the door from slamming? I feel like I put put some sort of spring, etc or pad but I am not sure what is offered. Any ideas? Thanks!
  2. smit1088
    smit1088 Well-Known Member
    1,582
    78
    Mar 15, 2011
    Stillwater, MN
    I have ben thinking about some sort of soft close mechanism from a cabinet door, but have yet to try one out.
  3. bondebond
    bondebond New Member
    2,079
    Aug 14, 2008
    I removed the spring at the top that is supposed to help close the door because I hate the sound of that door slamming shut.
    The other thing you can do is to add self stick felt or rubber pads between the door and frame. I have cut them to fit nicely.
    These are from the Mart of Wal.
  4. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
  5. Dubbya
    6,129
    52
    Aug 2, 2011
    Steinbach, MB
    Yep, that'll drive a person crazy!
    I was just gonna say, there are at least two ways to tackle the problem.
    [list type=decimal]
    [*]Use a cattle prod and negative reinforcement to teach people to use the equipment properly. (I tried positive reinforcement but that didn't work for long either. [;)])
    [*]Use a small door closer. You don't have to scream at anyone and it will never say "I forgot".
    [/list]
  6. E3 Junkie
    E3 Junkie Greetings from Granada Hills, CA.
    314
    Sep 22, 2012
    This is really easy to fix. Please tell everyone to stop slamming the door, and tell them the consequences of doing so will result in a severe beating with a pine branch followed by a traditional campfire stoning, followed then by a multiple poking with a hot marshmallow stick.
    I wouldn't recommend an auto closer, because they are typically rated for a heavier door. Using an auto closer would help the slamming, but would probably do more damage by bending the door during exit. The valving inside an auto closer isn't designed for such a light door. As an alternative you could use some very thin neoprene weather stripping where the door meets the jamb, but limit the amount you put on the jamb and only put it on the latch side of the door. Instead of striking with that metallic crash, it will only thud and rattle. BTW, that rattle is the upper window slider, and you're not likely to stop that even with the weatherstripping.
  7. dbbyleo
    dbbyleo Member
    198
    Jun 27, 2013
    I've put some weather stripping around the door jams to cushion it when it closes. You can find all sorts of weather stripping at Home Depot or lowes and all sorts of size. Just something moderately thin with adhesive backing.
    It has definitely helped. It does not sound so load anymore when the door closes.
    "... may the campsite be available and the local attraction be great at your next campground. Happy camping, camper!"
  8. G. Will Ickers
    G. Will Ickers New Member
    100
    Jul 31, 2014
    Maybe a lighter spring.
    Or possibly removing the spring altogether, and instead using a piece of rope or paracord or cable with a centerhung weight to assist with closing.
    I have a few of those cabinet door slamming preventer thingies in my garage, I may try to fab something up....
  9. Dubbya
    6,129
    52
    Aug 2, 2011
    Steinbach, MB
    Literally made me laugh out loud! [LOL] [LOL] [LOL]
  10. billy1
    billy1 New Member
    23
    Apr 24, 2014
    I used the loop side of Velcro tape cut into small pieces and placed it around the door edge. This created the cushion needed to quiet the door.
  11. nineoaks2004
    7,316
    3,056
    Dukes, Fl
    I used thin foam used for sealing around a door, it has glue on the back for easy attachment.
  12. silvermickey2002
    4,660
    460
    Sep 11, 2008
    Morris County, NJ
    I did the same thing. It did help with that slamming shut noise. But the DW and DS know to close the door and not let it slam shut.
