Slideout Sag
Discussion in 'Slide-Outs / Bunkends' started by Musictom, Sep 12, 2021.
  1. Musictom
    Musictom Member Gold Supporting Member
    43
    58
    Feb 13, 2021
    The dinette slide out on our 2021 Rockwood Freedom 2318g sags a bit. Not horribly, but it's definitely not level.
    Is this normal? Thanks!
  2. jmkay1
    6,872
    3,878
    I would say no,but I don’t have the Rockwood. Now a question, is your camper completely level first and on solid ground ? Sometimes if your camper isn’t exactly level or the base it sits on shifts or settles while setting up you may see a more noticeable sag or unlevel look on the slideout. Someone here with a Rockwood should respond soon so you can get a better idea. Good luck.
  3. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,298
    756
    Feb 6, 2007
    Centerville, OH
    Having owned two pups with slides I would say that’s not normal. When you say sags, how far out of level are we talking about?
  4. Musictom
    43
    58
    Feb 13, 2021
    I'd say at most an inch or two.
  5. crosbys2008
    crosbys2008 Active Member
    916
    174
    Sep 2, 2013
    Erie, PA
    Mine sagged but probably not more than a 1/2 inch. If it's really bad, you could possibly put support under the slide out. Not sure if that's good or bad, I've heard both.
  6. Annunzi
    Annunzi Active Member
    165
    137
    Jun 14, 2019
    Vancouver Island, British Columbia
    We have a 2020 Rockwood hw277 with a u shaped dinette slide, we get a little sag as well, probably about an inch.
